Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Tires and Wheels
- How to Replace Wheel Hub
Step by step instructions for do-it-yourselfers.
Rear Wheel Bearing Replacement HELP
First time to do this. Im following instructions that I found on a previous thread that has pics. Im at the step where im removing the hub from the lower control arm. Step says to put a ball joint fork between ball joint nut and cv (of which im a little scared to do.. afraid of damaging cv) Is it ok to pound the ball joint fork with a mallet wedging it between the ball joint nut and the cv???? or is there a better way? Looks like to me if I used ball joint fork below the hub unit to separate that it would damage the rubber surrounding ball joint. Help please and thanks in advance.
Supporting Vendor
St. Jude Donor '08-'09-'10-'11-'12, '14-'15-'16-'17-'18
Unless you have the GM tool (it wedges itself between top and bottom ball joint and screws to push the lower ball joint from the knuckle) the process most people use is to use 2 hammers and hit the area (one hammer on the knuckle) where the lower ball joint attaches to the knuckle.
Thanks for the tip. I ended up removing the upper control arm which gave me enough room to remove the cv axle. I then put a pitman arm puller on the lower and used it to push the hub assembly from the lower control arm ball joint. The pitman arm puller I used was just the right size to slide between the ball joint and surrounding rubber grease cap and fit over the top of the lower knuckle and ball joint bolt (after removing the nut obviously) and pushed the hub right off no problem. A jaw puller would have probably done the trick, too but my local parts store did not have one that I thought would work.
I installed the new wheel bearing and took her for a spin. The good news: No noise from the right rear!!!!! Awesome!!! (Sorry--this was my first major wrench turning on this car so I have to brag a little...)
I just bought the car about a month ago & I'm on vacation next week... Look out hills, here I come!!!!!!!!!!!
Stardusterone (10-26-2015)
Harbor Freight sells a ball joint removal tool for $20 that works great. I had to modify it by enlarging the part that slips under the rubber boot so it would fit around the ball joint shank with a dremel tool. It is way better than wacking your suspension with a BFH.
http://www.harborfreight.com/3-4-qua...tor-99849.html
Scott
Scott
Scott
Scott
Did you use a manual press to reinstall?
rear wheel bearing
Rick, I replaced rear wheel bearing ,big part with bearing in it , still have a noise when going down road and allthe way to stop, what could I have done wrong. I over torked the big nut first time . Please help . Thanks Ken kenphillips@suddenlink.net 903-330-2377
