Best place to install differential bung for temp gauge??
Old 09-23-2011, 08:29 PM
vettemann62
vettemann62's Avatar
Default Best place to install differential bung for temp gauge??
I am installing 3 interceptor gauges. They also take 2 exta inputs. I'd like to install a differential temp probe. But where do I weld the bung? I'd prefer it not be too low in the diff so I don't have to worry if it leaks .
Can the bung be welded and the sensor installed without having to drill a hole into the dif case? Just relying on the case temp.
Old 09-23-2011, 08:50 PM
20vette0107fatboy
20vette0107fatboy's Avatar
Ill tell you who to call, Call DTE or RPM transmission. Im getting a new diff this spirng put it and im also going to get them to make a place where i can install a temp gauge. I just talked to both of them a week ago and they said there would be no problem installing one for me so i can put a temp gauge. They would know where the best place to put one...
Quick Reply: Best place to install differential bung for temp gauge??
