pvc tube, left valve cover
Old 11-13-2011, 11:25 AM
car48nut
car48nut's Avatar
Default pvc tube, left valve cover
I have what I think is a vent tube on my left hand valve cover. It has a molded bend in it that has broken in half. I can not find a name for it, so I can order a part to replace it. Can someone tell me if I am on the right track? The tube runs at the back of the engine and close to the firewall. I do not know where it goes. Any help would be apprecated. The car is a 1998 c5 with a standard motor and auto trans. The tube that is in question, has oil vapor comming from it. Thanks
Old 11-13-2011, 03:39 PM
car48nut
car48nut's Avatar
I have added more info to the request. Thanks for reading this
Old 11-13-2011, 04:29 PM
lionelhutz
lionelhutz's Avatar
I just used a piece of hose to fix it, I believe 3/8".
Old 11-14-2011, 12:29 PM
dgrant3830
dgrant3830's Avatar
Wounded Warrior Escort '11
It is the PCV tube. It connects the driver's side valve cover to the passenger side by routing around the rear of the intake. Finally it "Y"s off and goes to the PCV valve itself which runs back to the intake. You can buy a new one from GM and last I saw, the whole tube assembly includes a new PCV for about $100.
Old 11-14-2011, 02:41 PM
johnson-rod
johnson-rod's Avatar
I replaced my PCV lines with plastic tubing from Lowe's at $.12/per foot.
I was a bit worried that it might not be the 'correct' type of tubing.
It is coming up to a year and 20K miles so I guess it's good to go.
Old 11-14-2011, 03:22 PM
sfc rick
sfc rick's Avatar
Mine also broke and I used an old 90* spark plug boot which fit like a glove.
Old 11-14-2011, 06:08 PM
Toque
Toque's Avatar
Location: Wylie TX --> Less is More, except under the hood !
I was looking at this the other night.
Mine is capped off factory from GM. I wonder why mine is plugged, and other car's have the extra line ?
Toque
Old 11-15-2011, 01:46 PM
lionelhutz
lionelhutz's Avatar
Because your car is newer.
Old 11-15-2011, 05:30 PM
Toque
Toque's Avatar
So then to me it begs the question.
If they deemed it not necessary on later C5's... then can the earlier C5's plug there line off too ?
Mine is a 04 Z06.
Toque
Old 11-15-2011, 05:48 PM
C5Natie
C5Natie's Avatar
Mine is a 04 Z06.
Toque
I believe its for cars with the LS6 style pcv system. LS1 style still uses the gommet on the valve covers.
Old 11-15-2011, 07:05 PM
Toque
Toque's Avatar
Cool. I never knew there was a difference in the LS1 vs LS6 PCV valve system.
Toque
Old 11-16-2011, 04:07 AM
rmata
rmata's Avatar
Yup, the newer style pcv systems use the valley cover and cap off the rear outlets on the valvecovers
Old 11-16-2011, 07:43 PM
Toque
Toque's Avatar
I just saw this... its a Crate LS6 motor.
The drivers cover has the same plug on the head just like my 04 LS6 motor has.
Old 10-28-2014, 01:36 PM
Kali949
1st Gear
Kali949's Avatar
Default Pcv
It's your pcv tube. In the corvette not only is there a pcv valve but a lengthy hose attached to it.
Old 10-28-2014, 05:55 PM
lionelhutz
lionelhutz's Avatar
3 year old thread - I would hope he's got it fixed already....
To pvc tube, left valve cover
Quick Reply: pvc tube, left valve cover
