New Battery, should I stay with DieHard from Sears???
Cruise-In VII Veteran
Johnson Controls and Exide seem to be the only 2 shops making batteries?
advance, autozone,napa, interstate, Walmart???
the Optima is about $200
thanks
thanks
i would go with the one with the best and easiest warranty process....
autozone (in the west coast) is by far the best for saving your warranty info on their system so no need to save receipts, they also have the optimas
i like to use optimas fyi
Steve,
If you want a red top, check with your local Interstate guy, I got mine for $140 (dealer cost) a couple of years ago. If you can't get a deal on one, the Delco sealed battery is quite good and ALOT less money.
Nothing wrong with Die-hards either, and I've never had a warranty problem with anything Sears makes or markets.
Jimbo
Jimbo
1 Post
Go with the Die Hard Platinum P4. Made by Odyssey, and cost less!!!
http://www.sears.com/shc/s/p_10153_1...=1322964904858
We started using these in airplanes about 8-10 years ago. I haven't seen anyone wear one out yet. Lightweight, super reliable, let it set for a year or two it'll still have a good charge, and never have to worry about leakage.
