Oil pressure reads 130 PSI and guage is pegged at 80
Old 01-12-2012, 08:13 PM
Johnz02Z06
Support Corvetteforum!
Johnz02Z06's Avatar
St. Jude Donor '14
Default Oil pressure reads 130 PSI and guage is pegged at 80
My change oil soon has been there for about a week now and when I go through the menu on the dash is today sid I have 2% oil life. The guage is pegged at 80 psi and the digital menu for oil pressure reads 130 PSI at idle warm. SO has anyone seen this?
Old 01-12-2012, 08:14 PM
lucky131969
lucky131969's Avatar
That is a strange problem. Have you tried searching yet?
AtlasInTheGym (04-27-2016)
Old 01-12-2012, 08:15 PM
Johnz02Z06
Johnz02Z06's Avatar
St. Jude Donor '14
figured id start here...I am now on hold with the dealer
Old 01-12-2012, 08:20 PM
pewter99
pewter99's Avatar
Received 1,194 Likes on 704 Posts
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
one of the biggest known problems with C5's....lots of info at the top of the page
65GGvert
65GGvert's Avatar
Received 3,221 Likes on 2,303 Posts
That was sarcasm. Search oil pressure sensor for several ways to change it. Must be hundreds of posts with the same problem.
Johnz02Z06
Johnz02Z06's Avatar
St. Jude Donor '14
I found a post on this....
http://forums.corvetteforum.com/c5-t...to-80-psi.html
Old 01-12-2012, 08:46 PM
65GGvert
65GGvert's Avatar
Here's a link to the method involving removing the intake manifold.
http://forums.corvetteforum.com/c5-t...um_id=1&arch=1
Old 01-12-2012, 09:20 PM
Jewjenk
Jewjenk's Avatar
Jumpin Jimminy a gold member since 2009 and asked the question. Do the so called senior members actually read the forum?
No this isn't sarcasm, it's reality, come on guys, I know as we get older the Oldtimers disease kicks in. There is at least one post a week, my oil gauge is pegged and the temp is off the roof?
Lets do some reading sometimes, everyone here is here to try and to help others, but it is up to you to attempt to help yourself so that we may help you.......................
Todays post further down the page......http://forums.corvetteforum.com/c5-t...ding-unit.html
Old 01-12-2012, 09:32 PM
Johnz02Z06
Johnz02Z06's Avatar
St. Jude Donor '14
Default forgive me...
I had a 1974 from 2007-2010 and just bought 02 Z06 less than 6 months ago and still learning.....
Old 01-13-2012, 10:06 AM
joe Villarreal
joe Villarreal's Avatar
yes the problem is your oil sending unit it needs to be replaced thats why its pegged at 80psi
Old 01-13-2012, 10:22 AM
dougbfresh
dougbfresh's Avatar
Search works the same way in all parts of the forum.
Old 01-13-2012, 07:16 PM
Big_George_S
Big_George_S's Avatar
Just had mine replaced by Westcoast Corvetts. I had a check engine light, unrealated to the oil pressure and then saw my oil was pegged at 80/130. I checked here and saw one person who managed to replace the sensor w/o removal of intake. My hands are too big and did not want to create other issues. If you have someone do it for you or if you do it yourself get the relocation kit and save to time and money for next time.
Old 01-14-2012, 03:57 AM
04blackice
04blackice's Avatar
Ditto.it oil press send unit.have fun with that one. Its not that easy doing it yourself.ill pay nexttime to have it done
Old 01-14-2012, 03:51 PM
corvetterene
corvetterene's Avatar
Just did mine last week. Had also the check engine light. Had code P1416. Check valve right. That is just an inch behind the oil pressure sensor.
iff you are going to chance oil pressure sensor, replace THE check valve allso.
To reset THE oil remaining, turn the ignitionkey on, but dont start. Step on the trotlle 4 times and the oil live is back on 100%
René
Old 01-20-2014, 02:02 PM
Morris Feldstein
Cruising
Morris Feldstein's Avatar
Default My 2002 corvette c5 reads exactly the same .
My guage has read the same for about 3 weeks now. I've been told the sending units are known to go bad quite often. I only have 65,000 miles on the car. I don't think I'm going to fool with that right this minute. It has nothing to do with you needing an oil change. You do have to remove your intake manifold or drill an access hole near your windshield wiper to get at it. I've heard drilling the whole makes it alot easier. I don't race the car or drive real hard I don't believe there is immediate danger. I would appreciate your input if you find out otherwise.
Morrie
Old 01-20-2014, 02:31 PM
Quicksilver Vert 01
Quicksilver Vert 01's Avatar
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
Originally Posted by Morris Feldstein
My guage has read the same for about 3 weeks now. I would appreciate your input if you find out otherwise.
Morrie
Since you've replied to a thread thats more than 2 years old, don't count on the OP to get back to you on this!
Failed oil pressure sensors have been a VERY common C5 Corvette problem. If you end up replacing the sensor, the ones made of brass seem to be the best choice for longer service life.
Old 01-20-2014, 06:58 PM
Morris Feldstein
Cruising
Thank you for the tip. I'm going to fix it. Morrie
To Oil pressure reads 130 PSI and guage is pegged at 80
Old 06-13-2014, 08:35 AM
Crazy Cowboy
Premium Supporting Vendor
Crazy Cowboy's Avatar
Location: www.EXOTICVETTE.com - FL Cruise-In VI, VII, & VIII
Cruise-In V Veteran
St. Jude's Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Question. Is the sensor and sender the same part just different name for it? If you search LS1 oil sender on ebay they are like $18. If you search LS1 oil sensor they are $40-50+ but they look the same.... Thanks guys
Old 06-13-2014, 12:47 PM
Chicago1
Chicago1's Avatar
I wouldn't ask about the clb locking or code c1214 either lol.
Old 06-13-2014, 06:19 PM
65GGvert
65GGvert's Avatar
There's one for oil temp and one for oil pressure. I'd check the part number. The higher priced one sounds like the right price.
Quick Reply: Oil pressure reads 130 PSI and guage is pegged at 80
