How to take off your C5 steering wheel with a regular steering wheel puller
Gasoline Addict
Here is my recent thread on the subject.
https://www.corvetteforum.com/forums...asier-way.html
The three prong gear puller I used fit underneath and around the center hub section of the wheel. You need to push back the rear plastic casing (unclip it) as much as you can to just get the hooks inserted at equal distances on the back of the hub. Anywhere else and they will either damage the wheel or break free. It took a while but I managed to maneuver my puller legs in the right positions.
Good luck!!
Good luck!!
Cutting it off may be the only option left! Damn... it will get messy.
Gasoline Addict
Ended up having to cut the wheel off and split the sleeve off the shaft. Made a huge mess, but the new wheel is on and the quick disconnect works great. Worth the hassle, for sure!
Wish I'd have seen this thread a week ago, I broke to J hooks trying to get my wheel of then decided to just drill and tap it with a 5/16"s bit and tap. Put two 5/16"s bolts in my regular steering wheel puller and it came right off. Glad to see I wasn't the only one with the problem.
Received 2,180 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Has anyone figured out what causes the hub to stick to the steering shaft??
Im surprised that heat isnt helping release it..
I forgot to swap the back plastic cover and found this out.
LOL (laugh is desperation) Yeah, I've read ALL of these threads, and I'm still not successful. (Mind you, I'm retired Master Mechanic). This *&^%$# wheel DOES NOT WANT TO BUDGE.!!!!!
So, to soothe my nerves, I installed my new headlights for the "Pause that Refreshes".
Today I'm back at the steering wheel.
Happy Easter 2015, guys and gals.
Gasoline Addict
