How to take off your C5 steering wheel with a regular steering wheel puller
Steering wheel removal is not easy to say the least.. here is how I do it now...yes I drill and tap holes..John
first off read the owners manual on un hooking the battery and disabling the air bag... after you do that here is the tools I use to take the bolts out of the air bag
after the airbag is out it looks like this
I have 2 black dots where I will drill 2 holes
next i take a center punch to them
next I drill the holes with a 1/4 inch bit
next tap the holes 5/16 by 18
next take your regular steering wheel puller with the 5/16 bolts, install it and pull it like you would any other wheel
here is what it looks like as it comes off
and when you reinstall it it looks like this
Interesting post...what does the "designed" puller for the wheel look like where does it pull from? Why didn't GM put threaded holes in the wheel like they used to? Any worries with the aluminum chips?
Thanks for this writeup. I've been interested in getting a covered steering wheel and this makes pulling the factory one much easier.
Cruise-In VII Veteran
About half these wheels are almost 'welded' to the column now; I'd be interested to see how many have success with any method...........sometimes you lucky.....others you don't
When my wheel comes off, I'm drilling and tapping and digging out my old school wheel puller. Thanks for the post 'cat
This is really a great thread
Sometimes that actually worked! Worked better when you had a helper doing the hammer work and you used your hands and knees to pull on the wheel.
Back in the day...when I was a dealership mechanic. We used to "break" the weld on the wheel to shaft junction by removing the bolt, using our knees to put rearward pressure on the wheel, and then doing the two hammer method on the shaft with a nut backed off to protect the threads.
I have done several.... I only stripped one out ... I then drilled with a 5/16 and tapped with a 3/8 16, used those bolts .. came out just fine..John
Oldtimer
This is exactly what I had to do to take my wheel off. Broke the J-hook aluminum slot in the steering wheel. So I went to harbor freight, bought a $25 tap/die, rented a puller that I knew what the threads were, selected two diametrically opposing locations, drilled, tapped....
because this is so much sturdier than the J-hooks which can move around, the wheel came of very easily.
I recommend this method!
Alex
Alex
simple but a great idea, havn't been able to get mine off, bloody will now
Received 2,180 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Before you remove the steering wheel, use a Wagner heat gun and heat the steering wheel aluminum hub to about 120-130 deg. Then use the puller and I bet it will come off a LOT easier.
I do the same heating on the harmonic damper hub when removing and installing my dampers. Makes a world of difference!
BC
BC
Gasoline Addict
The thread is getting resurrected!!!
I have tried two different pullers on my '01 C5Z, and snapped one of the j-hooks in half on one and then went with a three arm puller and ripped one of the freaking airbag mounts off. The wheel ain't coming off!
Used a heat gun to get it hot before the arm airbag mount broke off... didn't help. Haven't tried the hammer method described above yet, but will resort to it if nothing better exists.
Any other ideas? I have not yet drilled and tapped it, but doubt that it will work (Plan C). Plan D is to get the dremel out and cut the bitch in half and get it off that way. Frustrated, as I have a nice Sparco wheel, a MOMO hub adapter and an NRG quick disconnect ready to put on.
Please offer any other suggestions that have a chance of working...
https://www.corvetteforum.com/forums...asier-way.html
The three prong gear puller I used fit underneath and around the center hub section of the wheel. You need to push back the rear plastic casing (unclip it) as much as you can to just get the hooks inserted at equal distances on the back of the hub. Anywhere else and they will either damage the wheel or break free. It took a while but I managed to maneuver my puller legs in the right positions.
Good luck!!
