Can't read vin with scanner
Hi, maybe somebody can answer question about my 1998 c5 vin number. The vin cant be read on a scanner, even by a professional shop brand, i brought a hypertech max tuner and plug it in and kept getting' cant read vin error code' maybe one of u pros can tell me why. The scanner can access all other info,,,thanks
Received 2,180 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Carefully examine the female pins in your OBD2 port under the dash that the scanner plugs into.
You have damaged /spread female pins and they are not making proper contact with the scanner plug. Seen it TOOOOOOOOOOOOO many times.
You can most likely bend them back or if all else fails replace the OBD 2 connector
i had/have that issue with my DLC.
Bill, where can we get mo-better pins?
For datalogging with HPT I have the parts to bypass the DLC with the 18pin D-sub connector so I can connect directly to the HPT scanner.
Ron
Ron
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Well,,,,,,,,,,, I would check locally with placed like NAPA, Advance and Autozone. The Advance and NAPA here have aftermarket connector catalogs for replacement pigtails and I know the NAPA had a selection of male and female pins.
One of my local dealers had a big weather pack pin replacement set.
It was not GM .
If all else fails, contact Gene Culley and see if he can oreder you a replacement pigtail.
HAve you tried to adjust the damaged pins??
It was not GM .
It was not GM .
It was not GM .
And of course the pin takes a special crimper.
I just thought maybe you had sourced them......
Ron
