Help - Can't downshift from 6th to 5th
Old 04-21-2013, 06:37 PM
dcandel
dcandel's Avatar
Oldtimer
Default Help - Can't downshift from 6th to 5th
Took my car out for a nice long ride this afternoon and when trying to downshift from 6th to 5th it won't go into gear. I can upshift from 1st through all gears to 6th without any problems. But when I want to downshift from 6th to 5th, I can't find 5th gear. I had to downshift from 6th to 4th and then back up to 5th. I can downshift from 4th to 3rd to 2nd to 1st OK.
Any ideas?
Old 04-22-2013, 06:30 PM
Paul 75 L82
Paul 75 L82's Avatar
You will need to check the shifter alignment, then you need to flush or use the ranger method on your clutch fluid. Then I would change the trans fluid, I use the Royal Purple Synchromax and really like it. If none of that helps might start to save some $$$.
Old 04-22-2013, 07:23 PM
tlove32
tlove32's Avatar
Do you have a stock shifter or aftermarket? I have an aftermarket shifter and sometimes when downshifting to 5th, the nature of the shifter puts it in the 3-4 gate, and if I'm not careful, I end up in 3rd gear.
Old 04-22-2013, 09:50 PM
dcandel
dcandel's Avatar
Oldtimer
Stock shifter, and I do the Ranger method about every other week on a regular basis.
Old 07-28-2013, 01:46 AM
5.3Avalanche
5.3Avalanche's Avatar
Any ideas?
Did you ever solve this issue?
Old 07-28-2013, 05:30 AM
dcandel
dcandel's Avatar
Oldtimer
Decided to try to live with it rather than spend a bunch of money on it. Tried "double clutching" it from 6th to 5th and it worked ok some of the time, but not always.
Then, all of a sudden, the problem went away by itself. Why, I don't know, but now I can downshift from 6th to 5th without any problem. If you have yours checked out, let me know what you find. Mine's OK now!!!
To Help - Can't downshift from 6th to 5th
Quick Reply: Help - Can't downshift from 6th to 5th
