High rpm shifting problems.... clutch not disengaging.
I know for sure my clutch isn't disengaging completely. I can put the car in neutral, shove clutch all the way to floor, put shifter in 1st gear and the car will nudge forward. I'm also getting very difficult shifts at high rpm. I know with Fbodys the hydraulics are garbage and I've been told its the same thing with C5s. My question is what are the odds a new master cylinder will cure my problem or is it very likely its a pressure plate issue. Its a 45k 04 Z06 that's all stock. I've all ready tried bleeding and new fluid.
Is it only happening at high rpms shifts? Clutch sticking? Look at the Tick Master cylinder.
http://www.tickperformance.com/tick-...r-c5-corvette/
Received 2,182 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I had the same issue and hind sight, a new master cylinder most likely would have given me more time with less effort and money.
Try a new master first.
Well I've got it all taken apart now. I took my old master cylinder apart so I could use its rod in my new perfection one (made it adjustable) but I will say this. The inside of the stock master was completely full of what looked like wet mushed up pencil shavings caked in grease. I'm going to say the master will cure my problem, honestly after seeing exactly how the inside is designed and with all the gunk I don't see how it was working as good as it was.
common with C5's. new Master Cyl usually is the culprit. Tick seems to bee the one of choice. when installing new MC i would suggest a really good fluid as well... Amsoil or simmilar.. and once a year suck fluid out and replace.. there is a right up here about it on here.
S
S
Yea I cut open my old stock master cly. Same thing. Litter ally full of tar. I ran a tick master cyc for over 2 years, I just swapped a smaller bore 3/4 in tilton master cylinder in and the engagement is tons smoother and still high rpm shifts great. The tilton master in the tick kit is 7/8 bore.
http://forums.corvetteforum.com/c5-t...do-i-need.html
lil backround info.
http://www.summitracing.com/parts/til-75-750u/overview/
this is what i used to replace the tilton m/c that comes in the tick m/c kit.
be aware its not a dirrect replacement, you have to thread/tap the holes in the new master, 3/8x16 if i remember corretly.
lil backround info.
lil backround info.
lil backround info.
im not sure. can pm martin@tickperformance on here. its not a difficult job, just working under the steering Colum is a pita!! really liking the 3/4 bore tilton m/c so far.
Former Vendor
Just a heads up guys: we offer our kits with a 3/4" Bore Cylinder here in house for a $40.00 upcharge when the order is placed (we started this for guys using RPS triple-plate clutches.) 3/4" is the same bore size as your stock master cylinder so you won't see any huge increase in the ability to disengage a clutch, unfortunately (which is the reason we use a 7/8" bore cylinder regularly.)
