FIRST Ever Throttle Auto-Blip in C5Z utilizing Stock ECU - REVIEW
DIY-er or shop install? 485ish rwhp, 80% of the time track duty, but even on the street I try to rev match. $?.
Thanks for posting this thread. I am now a proud owner of the Auto-Blip device for my 03 C5 Z. I can not seem to find detailed install instructions. Can someone please direct me to them? I am a big guy, therefore I can not heel toe my Z with the confidence and consistence to go real fast at Road Atlanta... Any help will be greatly appreciated.
Just realized this thread was resurrected. Yes I have used this on a few tracks in Florida and it works great. As far as install instructions I would suggest calling AutoBlip and they will help you.
I have recently had LG Long tube headers installd and a tune done at a local shop. I think they either did not reinstall it correctly (different shop than the installer of the AutoBlip) or the tune was not optimally done. When I was at PBIR just prior to the headers and tune the AutoBlip worked flawlessly. 3 weeks later after the headers and tune the car was erratic when braking hard at the end of the back straight. At about 140 mph and braking hard with foot OFF the clutch the car would speed up, lurch forward and then brake, speed up, lurch forward, and brake in rapid succession. This cycle repeated about every second until you either come off the brake or turn off the AutoBlip. It was a bit scary to have this happen as you approach the end of the straight. So I turned off the AutoBlip and tried it again a few sessions later but the same thing happened. I have been practicing my heel toe up to that point but now I have made it a top priority. Just a bit concerned that some other electrical issue will cause this lurch forward for much longer during a critical time. You are essentially out of control and the car felt like it has a mind of its own when this happened. Quite an OH SH@T moment to say the least. I am going to have my tune checked by a Vette performance shop that specializes in track race cars rather than drag cars. Hopefully they can fix it but I don't think I am going to feel 100% about trusting this until they convince me it's fixed. In the mean time I am using every chance I get to drive on long straights at night and practice my heel toe even more when no one is around.
I will update this thread after I get the car checked out by the new shop.
C5Z06CE
C5Z06CE
I put mine in myself
C5Z06CE
C5Z06CE
I should have some info as to why this happened to me in the next week. Like I said above I suspect it's the tune my 1st shop put on the car. The new shop I am using specializes in road race track prepped cars. They should be able to figure it out.
Resurrecting a Dormant Thread.
Any Recent experience using and or installing the Auto-Blip on a C5 Z06?
I found a few threads referencing that the Auto-Blip was not available for the C5. I emailed Tractive Technology regarding the availability for the C5 and he replied that it was currently available.
Interested to here and recent experienece.
For several months I have had the auto-blip installed. Functionally it works fine, the only problem I had was forgetting to turn it off. After 6 hours it will automatically shut off, but I had an older battery and it caused the usual battery drain conditions. Put in a new AGM battery and no issues since. The leaning curve is getting the delay and time fine tuned to your driving style and realizing when you are staging every time you have the brake and clutch depressed it is going to blip on you. Now I am careful to make sure it is turned off when not in use.
#33
#35
When I read your other posts, I believe you mentioned it happened with auto blip on as well as off and after a tune and some engine changes. Also, since that time they have reconfigured the electronics for the C5.
#37
