Is this best option to get music from ipod?
So I did all the searches n its confusing...lol. Seems like this is the best plug n play solution, am I correct? Im not concerned it can be done for cheaper.
You have not indicated what device(s) you want to interface with.
I wanted to interface with iPods so I put in a DD Mods interface and I like it. There are two types where one connects at the radio and the other at the rear CD changer if you have one.
Here is another option that uses the earplug output from almost any device including iPods. It can be mounted most anywhere in the car if you don't want to modify the stock radio look.
http://forums.corvetteforum.com/c5-g...p-for-3-a.html
I love the mod to the radio but Im looking for plug n play. I do have the cd changer so wanted to plug into that. Is dennis on this board or should I ask him questions at his site. I just want something so I can use the ear plug output...
http://shop.doubledmods.com/ZUNE-C5-...HGM4-pxdx4.htm
It uses the headphone jack instead of the iPod connector. Works great!
Looks stock and I didn't have to rip into the radio as deep as in this post.
Here is exactly what I did with the CD Radio.
http://ls1tech.com/forums/stereo-ele...t-adapter.html
Here is the installed AUX jack location.
If you aren't really hung up on 100% "perfect" sound...then use a cheap FM transmitter.
I have an old iPhone 4 and I use an old unit I have had for 5 years. It's called a Jam Cast. Plugs into the lighter, charges, and broadcasts over the radio.
Fit is a little tight with the shifter but I'll live with it. If that doesn't work for you, there are a ton of FM transmitter units out there that would work.
I have a unit from DD mods and it's worked flawless for years. My son got the GM AUX for his Firebird and it went bad within a month. Got it exchanged and the next one did the same thing. Junk...
