changing rearend withan A4
Can I replace the whole rearend say out of a Z06 with a 3.42 into a auto car. I have the 2.73 gears and is a pig out of the hole. I was quoted $1600 to change it to 3.90 gears. They said with my case that was my only option. It's cheaper just to switch the whole rearend.
Received 2,180 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
IF and When you change out your rearend gears, you will also have to have a tuner tune your PCM so you maintain the correct A4 Shift points.
While you have the differential off the vehicle, at a MINIMUM, change the output seals.
Here are a couple post for your reading enjoyment..
C5 Differential Seal replacement: http://forums.corvetteforum.com/c5-g...on-photos.html
- C5, ragtopws6 , Upgrading your C5 rear with C6 Z06 guts, : http://forums.corvetteforum.com/c5-g...-z06-guts.html
- C5, Its_Go_Time, Output Shaft Install - Left and Right: http://forums.corvetteforum.com/c5-t...post1573407966
Also, in the A4 there is an adapter plate pressed into the front side of the differential that you need to transfer to the new differential housing. You can see the plate with its seal in the pic below.
