**Check out the latest Fan Controller for your C5!**
Supporting Vendor
CoolIt H2 and H3 Hard Wire kit
High Speed Fan Controller for your 1997-2004 C5 and C5 Zo6
For those that prefer to Hard Wire the Coolit Fan Controller in, we have developed latest version of the Coolit, the Coolit H2/H3.
It operates just like the original Wireless Coolit V series, but instead of using a wireless FOB to activate the fan it uses a switch and LED light.
The Coolit H2/H3 allows you to control your C5 Corvette's radiator high speed cooling fan with a simple push of a button allowing you
to control your radiator coolant temperatures. No need to pay for an expensive tune to just to change your fans on/off temperatures.
When switched ON, the LED lights up showing you that your Fan is running.
The CoolIt H2/H3 will NOT interfere with normal computer controlled operation of your fans.
Go here for more detailed info about then New Coolit H2/H3.
Only $119.95
http://hstrial-saccitycorvette.homes...ireCoolit.html
If you prefer to go with our plug and play wireless Coolit V2/V3.
http://hstrial-saccitycorvette.homes.../COOLITv2.html
__________________
Don't forget to check out our products at www.saccitycorvette.com
If you like our products, tell others! If not, tell us!
Supporting Vendor
Warm weather will be here before you know it. Now is a good time to install the New Hard Wire kit. We also have the original Plug and Play Coolit if you prefer.
Thank you,
Christian
Thank you,
Christian
Why does the notch matter? Im pretty sure I have turned it both ways and no issues that I know of. I have taken it out several times and never noticed which way the notch went now it has me wondering. So I dont know which to order
