Dash lights
2018 C5 of Year Finalist
St. Jude Donor '14,'18
Dash lights
Hi All,
Re: lights in the vertical push buttons for readouts like trip,gauges etc. Two of the lights are out. What's this all about to repair? 13 yr old car w/76k is failing electronically.
Thanks guys.
Joel
Thanks guys.
Joel
IPC controls lights
Hope this helps. Vincent
There is one bulb for every two buttons. They are incandescent and are in a small plastic base. The bulbs can be removed from the base and replaced. The OEM bulbs have a blue tint coating to make the light more White in color. TSTAR a Forum member here does LED upgrades and I bough a dozen of the OEM bulbs with bases from him.
You can also get uncoated bulbs from Radio Shack (#272-1092).
