Z06 Shocks fit FRC?
Might consider C6Z06 shocks new can be had for a few hundred bux. bolt right on no issues... (might also do the metal sway bar end links off a C6Z as well while in there for another couple bucks if you have the stock plastic links)
C6Z shocks (ALL 4) $234
http://www.gmpartsdirect.com/results...r=PKC6FE4SHOCK
Metal End links: $110 all 4
http://www.westcoastcorvette.com/p-5...3-c5c6z06.aspx
Received 2,180 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
C6 ZO6 Shocks!!
100% On the mark and FAR better choice for a shock up grade. Significantly improves the cars maneuverability and responsiveness in high speed driving and turns. Less than the C5 Z shocks and better performance!
You will Not regret the upgrade. YES, Also change the end links to metal.
Contact Gene Culley: He always has sales on the shocks and C6 springs and sway bars that also fit your C5.
https://www.corvetteforum.com/forums...nday-sale.html
Bill
Bill
Premium Supporting Vendor
Thank you for the referral. I would recommend the C6 Z06 shocks and you can order them on our site with the C6 Z51 sway bars. Check out my forum thread below on them.
https://www.corvetteforum.com/forums...rts-house.html
__________________
Phone: 484-334-8833
Owner of CULTRAG Performance
Shop Our Factory GM Parts Website
Phone: 484-334-8833
