Get Your LS7 Clutch Kit & Fidanza Aluminum Flywheel Option From CULTRAG Performance!
Premium Supporting Vendor
Hello All,
Thank you for your interest in our LS7 clutch kit. Many people ask us how much horsepower this clutch can hold. GM doesn’t have any official numbers but you can count on 650 horsepower. We have not had any reports of issues with this in any vehicle, unless you take it to the track and constantly dump the clutch. If you’re dragging the vehicle, then you need a different clutch.
With the 2004 Z06 GM updated the slave and master cylinders for a bigger bore to allow more fluid flow. The slave and master cylinders that we sell are only the 2004 Z06 and fit all C5’s from 1997-2004. The slave cylinder also comes with a new throw-out bearing. We recommend a new pilot bearing when installing as well.
To order, please call 484-949-2099 or go to the link below to ordering using our LS7 clutch kit configurator system.
Thanks. Gene.
Order LS7 Clutch Kit Link!
http://www.cultragfactoryparts.com/c.../ls7clutchkit/
Our independent in house weight test results were stock LS7 flywheel 26 lbs. 11 oz. and the Fidanza aluminum flywheel 13 lbs. 5 oz.
||--Genuine GM C6 Z06 LS7 Clutch Kit--||
24255748 – LS7 Clutch
12571611 – LS7 Flywheel
Both LS7 Clutch and LS7 flywheel are $519.99 total.
For both clutch and flywheel on our website, use part number ls7clutchkit under Chevrolet make.
We are now offering the LS7 clutch kit with the matching Fidanza 12.9 lb. aluminum flywheel.
Comes with LS7 clutch disc, pressure plate, alignment tool and Fidanza flywheel - $749.99
24264180 - LS6 Slave Cylinder – $152.24
12564455 - LS6 Master Cylinder – $154.99
14061685 – Pilot Bearing – $15.69
*Clutch does work in any LS1/LS6 drive train but must also have ls7 flywheel.
Also, you can only use LS1/LS6 hydraulics, not LS7 hydraulics.
We now also provide a clutch alignment tool with the kit and the kit from GM does not come with this so we have added it for your convenience!
Thanks. Gene.
__________________
Phone: 484-334-8833
Owner of CULTRAG Performance
Shop Our Factory GM Parts Website
Phone: 484-334-8833
The memorial day sale is over but thank you all for your orders and patronage. IT is greatly appreciated and thank you again to our brave service members for all you do and the risks and sacrifices you take every day.
__________________
Patrick Trageser
CULTRAG Performance
Your one stop source featuring the true experts for all GM Parts and Accessories, Lloyd mats, SLP Performance and Hawk Brake pads!
Order Your GM Parts at www.CULTRAGfactoryparts.com
patrick@cultragperformance.com
1-484-334-8833
CULTRAG Performance
1-484-334-8833
