under hood fusebox wiring diagram
Hey guys
I need to tap into a couple wires under the fuse box in the engine bay. Does anyone have a picture or diagram of the alphanumeric numbering schema?
I need to pinpoint a6 and e2 on a 2001 z06
Thx
Thx
That info is of no help. There are 3 connectors and they each have pins with those designations.
I would need to know what circuits you are looking for. If you are trying to tap off a fuse and not a relay I would suggest the following. They can be found at most auto stores for a few dollars.
http://www.ebay.com/itm/like/321412101602
I sure hope you know what current you will be adding to the circuits. There is virtually NO margin in the GM design. I just spent a month helping someone who had multiple burnt/melted wires from the idiot before him who overloaded several circuits and then figured putting 30 amp fuses in place of the 20amps would prevent the fuses from blowing. Well, the fuses did not blow but about 2 dozen wires did.
Wise people take power directly from a B+ source like the stud by the fuse box which feeds power to the fuse box. Additional relays can be added so no additional loads are introduced into the OEM circuits.
I can try and help you with designing a safe circuit to do what you want.
PS: Starting from the fuse box B+ stud there are 3 connectors, C1, C2, C3, in that order. Some FSMs show C3 in the center which is WRONG.
Received 2,180 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
100% on the mark!! What are you trying to do and why do you need to TAP into existing wiring?
There are usually MUCH easier and safer ways to accomplish mods.
The only time I have seen the necessity to tap into a wire is for a SHIFT LIGHT TAC SIGNAL but again, that isn't power but a signal wire.
Bill
Bill
Hey guys
I am going to splice in some connections for my 2 step to the ignition coils. By doing it this way I am only cutting 2 wires in the same location. These wires will both run through the wot box. These are also the recommended instructions from the manufacturer. This in not for power...just signal
Thx
Thx
Ok, you are looking for ignition voltage from C1 at A6 and E2 which are both Pink wires. These wires are powered when the ignition is in On or Start. Seems it would be easier to just pull the power from a fuse tap like I said in the above post. The fuses you would need to do this on are fuses 18 and 22. These fuses are powered and DIRECTLY feed those circuits once the ignition is On or in Start. If you don't like the fuse tap approach as a permanent solution you could at least validate the design works.
C1 is the connector closest to the passenger side fender.
Hope this helps, if not, let me know.
PS: If you need the actual FSM pin out picture let me know.
thanks for your help !
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Thank you!
There isn't one wire. From the MF switch there is a Tan for Low beam and a Light Green for High beam. I could tell you where to locate them under the dash (or fuse box) or you could use a Fuse Adapter to tap into the fuses for the HLs in the fuse box. You would need to use one Low beam and one High beam fuse.
Hope that helps. Not sure what you want to tap into for but beware there is little marginal for adding loads on the C5 circuits. I've helped more than one person who had a fire and/or melted wiring due to the stupidity of a previous owner.
Mr. Sam
Mr. Sam
topdown01 (12-22-2015)
Mr. Sam
Mr. Sam
Now that I know what you are trying to do using a side marker circuit or running light circuit would work. Let me know if you need any help on that. Not at home to see where the closest location would be to do what you want.
I agree it does not sound like a concern to add that into a circuit.
Mr. Sam
Mr. Sam
Not to hijack, but I have a ? For Dadaroo..I would have sent a message, but then I couldnt post the pics..im having a Magnuson Supercharger installed and it requires a coolant pump to be wired into the fuse box.I have heard the install using the method in the pics below can come loose or the fuse tab break.
Another installer said that they have wired it into the base of the box itself. I dont know what gauge wire or the importance of the red 10amp fuse with the bracket is and wondering how to tie the relay in more permanently. Im only looking to set up the wire for the installer to tie into.Any help would be greatly appreciated. Feel free to pm me directly if you wish.
Thanks,
Aaron
PS. Im pretty electrical dumb when it comes to electrical stuff, but I ca strip wires and follow your instructions if you can simplify it for me.
Not sure what size the purple fuse in the relay blaock is either.
Thanks,
Aaron
Their install looks fine to me. If you don't like the modified fuse (I don't either) then I would get a fuse adapter to hook up the Yellow wire.
Here is what they look like.
http://www.ebay.com/itm/5-x-MINI-ATM...QAAOSwl9BWG72P
Hope this helps. I would solder (and heat shrink wrap) or use a good connector to tie in the Yellow wire.
Mr. Sam
Mr. Sam
A-A-Ron (02-08-2016)
Thanks, I have place an order for the Add-A-Circuit fuse adaptor with Summit Racing. You're the second person to suggest that same device. Even Magnuson tech support said that should be fine since the yellow wire is called a "Trigger" wire..
Thanks for the input.
Hi all. Requesting information on a 2001 C5 Z06 Corvette under hood fuse box. I have codes of No Comm for TCS and HVAC. Fuse 5 is good but not receiving power. I do not measure any voltage across fuse 5 with the ignition turned on or the engine running. If I put battery power using a test lead to fuse 5 the HVAC works and the ABS and traction control lights on the dash go out. How does fuse 5 receive power from the battery? Any help would be greatly appreciated.
