Transmission Problems
here is the story,
i got a used transmission from another vette owner, had a transmission shop install it. Well now there is no oil circulating to the cooler, the trans started to climb in temp so i just have it parked at home. When i confronted the guy about the issue he asid he just removed the old one and installed this used one and didnt service it. he didnt flush the transmission or put a new filter on it. Now im stuck with a car that i cant enjoy driving cause the temp rises on the transmission. the guy also said that the transmission gauge on the car i could trust it, i told him the issue is that there is no circulation of the oil to the cooler so it could cool the hot oil. He said then there is something internally wrong with the trans, the trans shifts perfectly fine no issue there just is not cooling. Could a dirty trans filter cause the circulation to the cooler to be low or none at all?
Are you sure your problem isn't a blockage in one of the lines or the cooler?
If it is shifting then the pump should be pulling oil up through the filter pretty well.
Is the torque converter locking and unlocking normally? The fluid going to the cooler line is coming pretty much straight from the torque converter lock/unlock circuit.
Received 2,180 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I agree.. Remove BOTH lines from the radiator and see if you get circulation.
REMEMBER!!! Any fluid that you pump out of the transmission, needs to get re-added. That entails pulling the FILL PLUG with the engine trans warm and ENGINE RUNNING!
I would make sure that the trans is FULL to start with!
Are you sure that the shop filled it and filled it correctly???
I doubt if was shipped FULL. Ask that question and if they cant give you the proper answer,,, I would start there and make sure that its FULL.
BC
BC
St. Jude Donor '13-'14-'15
BC
BC
I wouldn't gamble---I would immediately get a "flush and re-fill" at another shop--
PS: A C5 does not come stock with a spate cooler--So are you talking about the cooler built into the radiator ? or an added on secondary cooler ?--( when you get a flush and fill at a Jiffy Lube type place--they connect onto the trans via the cooler lines connected onto the radiator)
If it was off any auto trans will eventually bleed back all the fluid back into the pan--That's why you check the fluid level with the engine running---Obviously you can't completely disconnect the line when running or it will spray fluid everywhere----BUT you can crack a cooler line just open to see if there is fluid pressure there at idle
