MAP Sensor Location to front of intake, thoughts?
Old 03-27-2015, 09:02 PM
Chris Edwards
Chris Edwards's Avatar
Default MAP Sensor Location to front of intake, thoughts?
Hey all, so I want to relocate my map sensor from away from the firewall on my C5, as I'm not 100% confident that it's sealing properly. The car has been tuned and runs quite well overall, but still has some idle surging. What are everyone's thoughts on the Lingenfelter map sensor relocation kits that put the sensor at the front of the intake? I've heard different things.
Old 03-27-2015, 10:08 PM
neutron82
Support Corvetteforum!
neutron82's Avatar
Received 1,261 Likes on 1,056 Posts
you could run a bead of clear silicone around the map to help it seal... I would rather do that than move it to the front, it looks ugly up there
Old 03-27-2015, 11:54 PM
Chris Edwards
Thanks but I'd like to relocate it either t'ing off the hvac or using the lingenfelter kit. The Fast is such a pita to pull on and off and I don't trust the map that close to the firewall.
Old 03-28-2015, 12:13 AM
neutron82
neutron82's Avatar
not any harder to remove than a factory intake in my opinion, 30 mins tops but it's your choice... you could even tee it into the brake booster hose and hide it under the booster/clutch reservoir or use another vacuum source out of sight, like behind the passenger fender or something like that... I just think it doesn't look very good on the front of the intake so I would explore other options first if I was doing it to my car
Old 03-28-2015, 12:47 AM
Chris Edwards
The angle of the vacuum port on the Fast is at a 45 versus the stock's 90. It's always a pain getting the oil pressure sender connector on. Maybe I haven't had a stock intake off enough but the few times I have there was more firewall clearance and more room, or so it seemed.
Old 03-28-2015, 12:59 AM
neutron82
neutron82's Avatar
why would you need to disconnect oil pressure sender when removing the intake?... all I have ever done is unplug the map, ac vacuum line, and I leave the booster hose connected at the back and remove the other end from the booster... assuming everything else is already disconnected, pull up on the 2 rear bolts and put some masking tape around them to hold them up while you use your other hands to pull up and remove the intake
Old 03-28-2015, 01:29 AM
Chris Edwards
Have you ever removed a Fast 92? The brake booster vacuum line routes behind the oil pressure sender and there isn't enough room to pull the intake with the booster line attached (clamped per oem) without disconnecting the sending unit plug. The bolt zip tied or taped is not the issue.
Old 03-28-2015, 07:23 AM
neutron82
neutron82's Avatar
I always manipulate the hose over the ops/cps harness while pulling it out... seems like you have your mind set on relocating it to the front of the intake though, there is really nothing wrong with doing it that way I just don't like the way it looks but if you can deal with it that's what matters... it would look cleaner if you cut and soldered in your own wires and run them with the fuel injector harness on the passenger side and come around the front of the intake with the tps wires
Old 03-28-2015, 06:36 PM
nullpointer
nullpointer's Avatar
I've taken my Fast 92 off (since sold it) roughly 10 times and never touched the oil pressure sending unit. Just relocate it, I ran black RTV around it in the back. Always had surging issues due to it.
To MAP Sensor Location to front of intake, thoughts?
Quick Reply: MAP Sensor Location to front of intake, thoughts?
