Whoa! Pull Key and wait 10 seconds with LCM5 installed!!!
Old 03-29-2015, 11:04 PM
WannaC5Z
WannaC5Z's Avatar
Default Whoa! Pull Key and wait 10 seconds with LCM5 installed!!!
Ok so my K-harness fried last year when my battery went dead. I removed the K-harness and installed the LCM5. Everything has been great until today. I even drove the car yesterday with no issues. However I go to back the car out this evening and get the notorious PULL KEY AND WAIT 10 SECONDS warning. I don't and when exceed the 2mph the car dies. What the heck?!? I thought this could no longer happen with the LCM5 installed??? Oh and I put a new battery in it last year when the old one fried the K-harness.
Old 03-29-2015, 11:51 PM
73Corvette
73Corvette's Avatar
Did you do the brown wire mod, when you installed the LMC5? Tuner can take out the 2 mph feature.
https://www.corvetteforum.com/forums...-gremlins.html
The following 3 users liked this post by 73Corvette:
68Malibu383 (09-18-2021), Johnny Hardcore (09-27-2021), soysauce (09-16-2021)
Old 03-31-2015, 06:58 AM
Cybermind
Cybermind's Avatar
Don't want to knock the LMC5 but what's wrong with a good-old CLB? I guess it's considered too old-school these days...lol. I know that my CLB which I installed about 6 years ago has been bulletproof. Installed it and forgot it. It's never acted up. Just saying.
Good luck with your issue.
Old 03-31-2015, 07:59 AM
4XLR8N
Pro Mechanic
4XLR8N's Avatar
Received 1,652 Likes on 1,209 Posts
I installed the CLB several years ago and will still occasionally get the pull key and wait 10 seconds message. When I had the car dyno tuned last summer I had them change the fuel cutoff to 200 mph so that isn't an issue anymore, but it is still aggravating when it happens. Of course, the column no longer locks so no issue there.
I also thought that the CLB would eliminate this issue, but I guess not in all cases...
Old 03-31-2015, 08:06 AM
Koufax
Koufax's Avatar
Yes, I get that message. I could install the brown wire but installing the unit was such a pain that I'd rather just wait 10 seconds. It's my understanding that this unit will prevent the steering wheel lockup even without the brown wire installed, so your choice is to (a) spend 30 minutes crawling around under the dashboard to get that brown wire installed, and (b) spend 10 seconds every month or so waiting to reinsert the key. I chose option b. Then I'm not the fastidious type. I get a warning light on my dash to shift from first to fourth gear, which I ignore and shift into second with no problem. For some folks, that's not good enough. They don't want to see that warning, even if it has no effect. If I could wave a magic wand and make it stop, I would. If it were to cost me more that $2.00, I'll just chuckle when I see that warning light up in vain.
pewter99
Support Corvetteforum!
pewter99's Avatar
Received 1,194 Likes on 704 Posts
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
yeah I got nasty PMs when I posted that kind of stuff...as an Admin I am not supposed to have an opinion I guess. fact is I didn't have to jump through hoops and make changes after I installed my CLB to get it to work...it just worked
seen it once in my 99 in 15 years......happened less than 5 times in the 02......
Old 03-31-2015, 08:17 AM
73Corvette
73Corvette's Avatar
Did you do the skip shift eliminator mod?
Old 03-31-2015, 08:44 AM
73Corvette
73Corvette's Avatar
Your right nothing wrong with it...
It functionally does the same thing a CLB does except that it is connected directly to the BCM eliminating all the factory and recall wiring and hardware.
Old 03-31-2015, 09:22 AM
bjones7131
bjones7131's Avatar
I too got the message after installing the lmc5. First make sure you let the computers have time to come up after you turn key on but not crank or U may get the message. Second if you still get the message call Richard at comp. and let him guide you as to what to do. I was instructed by Richard to install brown wire mod and did so and next day I got the message again even after the brown wire mod. and the 5 MPH cutoff got me as well. Not sure why but I went back through the brown wire mod process and everything worked as it should but I found a HP tuner to increase my MPH to 245 mph. Only thing I can figure is I had a loose wire somewhere, my wheel never locked but the MPH got me so that is why I had it changed to 245 MPH, cost me 100.00 buck for a two minute job but peace of mind is worth the 100.00 bucks. Good luck
Old 03-31-2015, 09:41 AM
Irony
Irony's Avatar
I am the 3rd owner of my lightly modified and tuned '01. I just installed a new battery and got the warning message.
How can I check if a tuner had increased my MPH cut off; other than driving off and waiting to see what happens?
Old 03-31-2015, 03:30 PM
73Corvette
73Corvette's Avatar
Originally Posted by 8VETTE7
Only way to check other than trying to drive is to have either HP Tuners or EFI Live tuning software and check how the PCM is programmed relative to the 2mph fuel shutoff speed. Nothing that you can physically look at.
Thanks for jumping in...you are the man!
Old 07-06-2015, 02:39 AM
Daddie O
Daddie O's Avatar
I also installed the LCM5, and now get the dreaded pull key wait 10 seconds, then the fuel cutoff. I called Richard, and he suggested the brown wire mod, which I have yet to do because I am not mechanically inclined. I deeply regret ever getting the LCM5, and paying a mechanic to install it. I should have followed the old adage, "if it ain't broke don't fix it". One of these days I will have to pay a mechanic to do the brown wire mod, and hope that nothing else goes wrong.
Old 07-06-2015, 11:09 AM
Daddie O
Daddie O's Avatar
You should have just waited for the system to fail and gotten stranded. Much preferable option to messing with something that ain't broke.
Recall was already done prior to my purchase of the car, so there was no risk of being stranded.
Old 07-06-2015, 11:14 AM
Macleod52
Macleod52's Avatar
The recalls GM performed did not fix the issue.
Old 07-06-2015, 11:28 AM
dbgoodwin
dbgoodwin's Avatar
The recall was done to my z when the column locked, 2 days before I had to take a 1500 mile trip. If it had waited 2 days I might have been stranded down in some terrible state like Georgia (kidding) ruining my whole vacation. If that's not a sign to fix the issue, I don't know what is.
Old 07-06-2015, 11:55 AM
bobby777
bobby777's Avatar
Soooooo much wrong information in the hands of a manual transmission (Z06) owner.
If the recall had NOT been done you would have far less likelihood of getting stranded.
It's the recall 2mph fuel shutoff and/or GM K Harness installation that are the causes of getting stranded.
Chuck--exactely what does the GM K-harness do? Is it a module?
Old 07-06-2015, 12:04 PM
Daddie O
Daddie O's Avatar
I did not experience any pull key error or fuel shutoff until I installed the LCM5.
To Whoa! Pull Key and wait 10 seconds with LCM5 installed!!!
Old 07-06-2015, 01:43 PM
Jumper11
Jumper11's Avatar
I got an 02 coupe and went through 3 variations of the LMCR-5 mode. Talking with Richard from compliance worked for me. Apparently there's a couple of unique C5s that the first two versions didn't work. They all kept the steering unlocked but the first two version gave me the wait 10 sec message. The last version installed last year and no issues at all. Richard is a good man. Call him.
Old 07-06-2015, 04:42 PM
dbgoodwin
dbgoodwin's Avatar
Neither did I for almost 3 years. Then one day it happened. That's how things happen Ya know?
Old 07-07-2015, 11:51 AM
2FAS4UU
2FAS4UU's Avatar
Default Lmc5
After watching and reading the posts build in numbers about their LMC5 issue's ( 'the so-called absolute fix' ), I remember taking some tongue lashings from certain forum member/s when I posted that I had the pin removed from my steering column lock after I had the column lock on me while driving, and I stated that I don't rely or trust my safety on electronics, these posts confirm my beliefs. A simple ground issue alone can change all the dynamics of 'ANY' electronic fix, GM or aftermarket !! Jus Say'n
Quick Reply: Whoa! Pull Key and wait 10 seconds with LCM5 installed!!!
