TCS/ABS code 1227, I think I fixed it
When I bought this car back in January it had a bad LR wheel bearing and the dreaded TCS/ABS module issue, I fixed both immediately.
Car has been fine for a few months, then the other day I hit a bump on the interstate and the light came on, TCS/ABS code 1227, LR wheel speed sensor. Clear the code though DIC, next bump, bam....back on.
So I picked it up on the lift, inspected it, wires ok, ground good blah blah blah. Cleared code, bad bump..DING, light back on....same code.
Back on the lift to inspect, nothing visible. Unplug the connector, take a small pick and tighten (push together) the female ends of the connector. I put about 200 miles on the car yesterday, seems fine.
Just a heads up.
Just a heads up.
