Oil pressure dropped (@20psi) loud ticking from motor (video)
lifter fail
trust me .....BTDT
trust me .....BTDT
Received 2,180 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
NO!!! The port is on the BLOCK and it has a plug in it. Look down below that point and a little forward.
If you look hard, you can see it in this picture. That large HOLE on front of the block is the main oil pressure port. Its connected to that hole:
You can easily see it in this picture:
BC
Bill
BC
Bill
I had a similar pressure drop. Two dealers shops could not come up with the answer. Third dealer mechanic did: faulty oil pump. All bearings worn down to brass metal Pump registered pressure ... Just not enough pressure
Ticking ? most of the time it's a lifter ,not that hard to find if really loud put your ear close and can here it or put your hand on the rockers and you can feel it or loosen up on the rockers one at a time and the bad one will get really loud .A can lobe may have be going ,Right now is not bad but keep driving and may lead to big prop. It's more than likely in the valve train.. It could be oil pump never check the oil pump with your inside gauge need to check it off the motor to get the real deal if not the pump valve train the cylinders look good rockers look good push rods look good got to go down past the push rods crank shafts don't tick they knock the rods also the only thing I know that ticks is my watch and the valve train in the motor..
Like pewter99 said and ive already said, its a lifter. Or a few of them at this point. Depending on how long u have ran it that way (probably already too late) the cam will be trashed with the lifters. Pull the heads and see for yourself....
at any rate the OP needs to start troubleshooting before it gets really bad. if the lifters have failed to the point you have a drop in oil pressure and cam lobe wear metallic bits are sure to be floating in the oil.
may not have damaged the bottom end yet
address the issue before it does
At 120 K it might be time to pull the motor and freshen it up, or bandage and send it down the road, I'd think twice about the Harbor Freight stethoscope, the sound clarity is poor and it doesn't pick up the small sounds, invest in a Blue Point / SnapOn for about $28 vs the HF @ $5 , your money will be well invested in quality diagnostic tools.
I have a better idea buy some tools and start working on it .. Just being a smart *** but really there not hard to work on and not giving the man all your money is a good thing .Charge yourself $125.00 hr. labor and you'll be in the rich in know time ..It's all on the net and on this forum just ask we know stuff OK some know stuff some think they know stuff..
Changed the oil and it had a shiny silver look in the sunlight when swirling it around. I ran it thru a mesh screen and didn't find any slivers. I put a magnet in the oil and didn't pick up anything. Still have to pull the intake manifold off.
I'm seeing about a 15psi increase in oil pressure
Ok thank you, do you think I could put a telescopic magnet down there and feel play in a bad lifter? By play I mean be able to pull it up and down a bit with the magnet. I'm not sure what actually happens to a lifter when it "goes"
#34
bearings turn to dust when they get fried. if you starved the bottom end at some point that could explain it all
that haze powder can be bearings, have done that before. tiny little speckles in the oil
you try 50w oil yet and see if the pressure comes up?
#36
if it's a lifter you're still going to knock even with higher pressure. if the lifter is knocking because of the low pressure thanks to excessive bearing clearance thicker oil will quiet it down
it's a troubleshooting method for what you're encountering
sending in some of the old oil is a great idea btw
#38
I had the EXACT same sound 3 years ago after a quick high speed run merging onto the high in the hot summer heat. This was the result......
After many discussions, not on this forum, I believe oil was the culprit. That cam and lifters(although stock lifers) had been in my car for 3 years no problems. After a 3rd gear 6k rpm in 95* Florida weather, I had the exact "tick, tack, and clack" your hearing. A few lobes and lifters.
Just lifters and cam? Bottom end was fine?
#39
I know its hard to believe some random peeps on a forum. But the second I heard your clip, I knew. Yup, when I heard the problem in my ride, I limped the car home and didn't drive it again and only started it twice to for diagnostics. My bottom end was fine. I had custom cam speced, and went with LS7 lifters. Of course I believe its a "standard" replacement lifter now anyway. The springs that were from the first cam build were PRC EHT .675 springs. They were fine and hadn't lost much of anything for pressure. My mechanic inspected them as did I before I took it to him and they were fine for reuse. Just had the lifters replaced with the cam and rolled.. Out of curiosity, what oil were you using?
#40
x2 on the oil
if you had solid oil pressure i'm surprised this happened if it was a half way decent oil like M1 high mileage or better
were you using some low pressure formula like standard mobil one or some off the shelf syn with a neutered zddp level?
i've roasted bearings before from oil starvation in high g corners but never have killed a cam
