Windshield Wiper Adjustment - Syncronization.
I looked at all the old posts and I still can't adjust the wipers properly. I am opening a new thread in the hope I can get some answers. I tried positioning the little stop tab 5 CM before stop...no dice. I looked at a photo that said the knoch should not be in the slot when the motor is at rest. I adjusted to this photo position. No Dice.
At intermittant wipe stop position, the blades are in standing up on the windshield. The drive side wiper never makes a full sweep. Adjusting by feel is not my strength. The service manual is not help either.
I already wiped out the $100 drive side wiper. SO I need help .
I am totally lost...nothing has worked.....at least 25 adjustment attempts.... I am not even close......
There's not much to installing the wiper arms. With the motor off put the arms on so they sit on the rests on the cowl cover. If they don't work correctly after doing this then you need to pull the cowl cover and figure out what is wrong with the wiper motor or linkage. I'm betting the motor has an issue and is randomly stopping instead of making the proper sweep.
2. I think the mechanism that connects the two wipers is not being installed correct. But I cannot figure out how it is suppose to be installed. The original wiper motor would not stop so the wiper transmission was in a position where the wipers were stuck on the windshield when I stopped the car. Now I cannot figure out how to position the transmission arm mechanism to its proper position. [/LIST]
I believe the arm on the motor/transmission should pretty much be straight out towards the passenger side just behind the one wiper assembly mounting screw when the wipers are parked. It should be pushing the operating arm as far to the passenger side as possible which is how the wiper arms get rotated into their park position. Both levers that run the wiper shafts should be parallel and facing to the rear of the car with the link connecting them going straight across side to side. I've never gone past just removing and replacing the assembly to clean the crap out from under it so I can't help on the gearbox and motor. Have you tried Google searching for pictures of the assembly?
Problem Solved
https://www.corvetteforum.com/forums...rocedures.html
Thanks for the help.
