HUD line
HUD line
Hey all, I just bought my first corvette an 04 convertible. I am seeing some green horizontal lines going through the speed and rpm of the HUD. Almost looks like some kind of inference. Can anyone shed some light on this issue?
Your HUD display is bad. If you want to replace it by DIY, I can provide the info. Not that hard to access but you have to pull the dash pad. It is not as hard as it sounds. Many novices have done it with no issues.
I just added a HUD to my 01z, as dadaroo stated its really not hard at all to get to you can have the dash out in less then an hour. There is a lot of info online on removing it there very helpful
Received 2,180 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Have you tried to remove the HUD, clean the pins where it connects to the IPC and the pins on the hud its self and reinstall. Sometimes that's all it takes.
Bill
Bill
No need to pull the HUD projector just yet, as that requires removal of the entire dash pad.
