New setup, where ill be with HP wise.
New mods:
EG Whiplash Cam, on a 112
243 Heads with Texas Speed stage 2.5 porting w/ 2.02"/1.575" valves
PRC valve springs
FAST 92mm Intake, LS2 90mm TB
LG Pro Long Tubes with hi-flow cats, Modded Ti's
3.42 geared rearend.
Hoping to be at or break 400hp.
PRC valve springs
c5z06.O (10-07-2015)
my 03z made 448rwhp / 399 rwtq
ported 243's
224/230 581/592 114lsa cam
ported fast 92mm / ls2 tb
kooks lt's and off road x
3.73 gear
varraram ramair
underdrive pulley
my 01z 428rwhp / 390rwtq
PRC stage 2.5 243s
219/230 .607 .604 117
unported fast 92mm / ls2 tb
texas speed lt's off road x
varraram ramair
underdrive pulley
3.42 gear
you should be well into the 400's
ported 243's
3.73 gear
varraram ramair
underdrive pulley
PRC stage 2.5 243s
varraram ramair
underdrive pulley
3.42 gear
Where did you purchase
If you don't mind telling. Where did you purchase your 92 90 set-up?
From the looks of those goodies, I'd say you should. Also very important to get the best tuner you can, to get everything setup.
Received 1,261 Likes
you will break 400 EASY... mine made 420rwhp with longtubes, much less aggressive cam than the one you will be using, stock 243 heads, and stock intake/tb
St. Jude Donor '13-'14-'15
Very similar to my C5 mods and I was exactly at 400 RWHP---with an automatic---
An auto trans in a C5 had about a 20-22% drivetrain loss whereas a 6 speed manual only had a 10-12% drivetrain loss---Not so anymore on a C7 where the auto trans now is equal to or less in drivetrain loss
