Skip Shift bypass worn/burned out???
4th Gear
Hey guys, I installed one of the "skip shift" bypasses on my Z06 about 8 years ago. Now all of a sudden the car is throwing a code that says "Skip shift solenoid control circuit".
Has the bypass worn/burned out? Any help would be greatly appreciated.
Grasshopper, you need to post in either the General or Technical section. I and others do not want to try and look at two Threads to try and figure out what is going on in the diagnostics. This can be a BIG deal with a significant issue. Looks like you have your needed input in the General section.
I suggest if you want to know if a cosmetic issue is tasteful then post in the General section, If it is a technical one like yours was it should only be posted here.
Good Luck. I will follow your other Thread to make sure you get it fixed. So long as Chuck (aka 8VETTE7) is helping you are in good hands.
Mr. Sam
Mr. Sam
