C5 Gauge Cluster??
C5 Gauge Cluster??
Is there information stored in a 1999 or 2003 analog gauge cluster and will the 2003 Z06 gauge cluster swap out with a 1999 cluster? They look identical right down to the connections. I want to put the 2003 Z06 cluster in my 1999 because I like the carbon fiber background on the 2003 Z06 cluster and all the controls are more crisp looking. Both cars have the HUD but the 1999 has tire pressure monitoring. I was wondering if the 2003 cluster would display the information from the tire pressure monitoring system even if it comes from a car that doesn't have the TPMS or if the clusters store programming information about the TPMS, mileage or any other information. I have the clusters removed from both cars thanks to a removal link I found during a search. I pulled the cluster to mainly replace the bulbs with blue LED's which leads to another question. I have the side control LED's but cannot figure out what illuminates the actual gauges. Are there bulbs or is there some luminescent material at work??? Thanks
Yes you can swap them and everything will work and display TPM sensor info.
However, if you don't swap the large green motherboard you will have to have the mileage reset since it is stored there.
This may help if you want to swap it.
https://www.corvetteforum.com/forums...post1570380674
Mr. Sam
Mr. Sam
That's the power supply for them that is piggybacked on the rear of the IPC assembly. Neither they, nor the power supply, is available as a separate item(s). Buy used as needed.
Thank You
Thanks everyone. I really enjoy this place. You guys never fail to answer a question thoroughly. Thanks for the link about how to disassemble the gauge cluster dadaroo. My Z06 only has 33,400 miles and my 1999 has 87,100. I could shave about 50,000 miles off my 1999 by not changing the motherboard but I wouldn't do that unless there was no way around it....I plan to keep my 1999 and pass it to my son later in life but you never know as a Corvette owner so I'll change out the green motherboard. Thanks again for the answers and dis-assembly link. It all helps a bunch.
No "bulbs". Two black light/UV tubes do the work. Phosphorescent or luminescent type material on the gauge/pointer faces.
LoneStarFRC is correct on the UV bulbs.
Thanks Again
You have to drive it to get any readings.
FYI, you can enter the TPS programming mode using the DIC and then program the sensors with a big magnet. It's really simple to do and should only take 5 minutes at most.
If I had both cars in front of me I'd be swapping the ABS system from the Z into the 99 or at least taking all the parts off so I could when the EBTCM on the 99 fails.
Thank You
The EBTCM is the controls of the ABS/AH/TC system and there are no new modules available for 97-00 cars. Also, the SWPS is also not available for 99-00 cars but I believe you could use a 97-98 SWPS if your car doesn't have AH.
Your life will be much easier if you learn to use the forum search or Google to find info.
The forum search is to the top right on each section in a drop-down. A forum search for EBTCM or EBCM will give you more info than you'll ever want to read. A forum search for TPMS will give lots of info on that system too.
A Google search for "c5 corvette EBTCM" will also get you lots of info. Similarly. a search for "c5 corvette tpms programming" will get you lots of info on this too including a YouTube video of the procedure as one of the first results.
Hint - Putting site:www.corvetteforum.com will limit a Google search to this forum. Google does a better job than the forum search anyways.
As for the magnet, just use a good strong one which is probably explained in the video or one of the search links.
Vendors sell a good magnet to do this but something like an old speaker magnet will work. If the horn will beep then the magnet is strong enough.
Tire Pressure Monitoring Sensor Programming
The Tire Pressure Monitor (TPM) system interfaces with the Instrument Panel Cluster (IPC) through the serial data line. Once the program mode is accessed through the IPC, each sensor's unique identification code can be programmed into the receiver's memory. Each sensor must transmit the unique code in the proper sequence. A magnet must be held close to the sensor in order to force the sensor to transmit the identification code. The IPC will display a message as each sensor is programmed, and when to proceed to the next sensor for programming. The receiver also sends a message to the BCM to sound the horn one time, indicating that the sensor properly transmitted an identification code. If the programming sequence is cancelled before any sensor is programmed, or if the vehicle's battery is disconnected, the receiver will remember all current identification codes. As soon as the receiver learns the first sensor identification code, all previously stored codes are erased from the receiver's memory.
Tool required (any medium strength magnet, U or Disk type)
The official GM tool is (J 41760) Tire Pressure Monitor (TPM) Programming Tool.
1. Turn the ignition to ON.
2. Press the RESET button in order to clear any IPC display warning messages.
3. Press and release the OPTIONS button on the DIC to scroll through the display options until the IPC display is blank.
4. Press and hold the DIC RESET button for 3 seconds.
Notice: Refer to Body Control Module (BCM) Programming/RPO Configuration in Cautions and Notices.
5. Press the OPTIONS button again until the TIRE TRAINING message appears.
6. Press the RESET button until the IPC LEARN L FRONT TIRE message appears in order to begin
the programming sequence.
7. Install the J 41760 Tire Pressure Programming Tool over the left front valve stem.
8. The horn will sound, indicating the left front TPM sensor is programmed.
9. When the horn sounds, proceed to program the next TPM sensor in the following order as directed
by the IPC messages:
- LEARN R FRONT TIRE
- LEARN R REAR TIRE
- LEARN L REAR TIRE
Programming Cancellation
1. The programming mode will be cancelled if any of the following conditions are met: - The program mode is exited through the DIC.
- The ignition is turned to OFF.
- All four sensors have been programmed.
- The TPM system has been in the program mode for longer than 2 minutes and no sensors
have been learned.
2. If the program mode is cancelled with less than four codes stored, the receiver will only accept the codes programmed up to that point.
- LEARN R REAR TIRE
- LEARN L REAR TIRE
have been learned.
Thank You
- LEARN R REAR TIRE
- LEARN L REAR TIRE
have been learned.
- LEARN R REAR TIRE
- LEARN L REAR TIRE
have been learned.
Thank you for the programming information. I'm printing a book full of instructions and pictorials from the tech experts here. Thanks to everyone again. I appreciate it very much. Your time is valuable so I'm very grateful for all the help....
