slave cylinder
slave cylinder
my slave cyl line has a leak right under the master cylinder is there a way to fix this without having to change the whole slave cylinder? the slave cylinder is not that old. there seems like there has to be a way to fix this without having to take the whole tranny out. any ideas?
Received 2,180 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The hydraulic lines are two separate lines. The one that comes off the master cylinder and the line that comes off the slave cyl. They connect together with a male and female quick disconnect fitting.
Which of your lines are leaking?? The line that comes off the master or line on the slave??
Bill
Bill
Bill
Bill
CI 6,7,8,9,11 Vet
St. Jude Donor '08
If that fails,, I may be able to help ya/
BC
Well,,,, Good news and BAD NEWS. First the BAD news... GM does NOT sell just the line.. The good news is,, you can probably have one made.. Look in GOOGLE for your area and see if you can find a place that make hydraulic lines. Motorcycle/ 4 wheel shops are good places to look. Sometimes,,, they can use your fittings and make it work.
BC
BC
Buy a used one, knock out roll-pin, install replacement line, you're done.
See post #2.
no I changed the harmonic balancer must have put a pinhole on the line by pushing it up. by looking at it right were the foum booty protecter right were the steering shaft is the foam looks like it held water and the line is rusted.so all it took is alittle moving around and it sprung a leak. the slave is fairly new. car sat for 3 yrs after the new clutch went in
