intake manifold swap
St. Jude Donor '15
finally decided to put my BBK SSI intake manifold and TB on today. took about 1.5 hours. here's the before. added some length to the small vacuum line to make it much easier to put back on.
Received 1,261 Likes
do you have plans to get it tuned/dynoed?... I'm curious to see the gains and if it is prone to heat soak as engine bay temps rise or after multiple runs
mrr23 (09-10-2015)
St. Jude Donor '15
My plan is to dyno in late September to see what the difference is. Heat soak is a non issue. I've monitored the iat temps and compared the bbk air intake to air temps and my friends stock bridge iat temps via hptuners. No difference. Air temps to iat temps were about 10 to 12 degrees higher.
well your iat sensor looks to be before the intake manifold (unless you moved it after those pics were taken) so that won't really tell you much
mrr23 (09-10-2015)
St. Jude Donor '15
You wondered about heat soak. The bbk air bridge is aluminum. Sitting still, the air temp would rise. As soon as i would start driving, it would drop to just around 10 degrees above ambient temps.
Received 19,307 Likes
'20-'21-'22-'23-'24
That's a nice looking intake. Will be interesting to see what the numbers are after the tune.
mrr23 (09-10-2015)
I had that manifold before I switched to a FAST. That manifold, as expected, gets really hot. The computer won't pull timing, however, as the IAT sensor is before the manifold. If you're already on the verge of spark knock that manifold will push it over the top, at which point the computer will drop into the low-octane table and pull significant timing. Cold it will out-perform the stock LS1 and LS6 as they advertise.
mrr23 (09-10-2015)
