ate 706202 brake fluid
anyone use ate brake fluid.see good reviews.dont tract or race my car.all stock coupe.just wonder if anyone uses it or other recommendations.merry Christmas to all.
I use Prestone Dot 3. Why mix things up? It's OEM specified and works for millions of cars.
I use to use their ATE Blue until the Feds decided people were too stupid to know it was brake fluid because it was blue. I have now switched to Castrol DOT 4. It replaces Castrol LMA (Low Moisture Absorption) and maintains high wet/dry temps.
I use Ate Superblue and also Type 200. I switch back and forth so it is apparent from the color change at each caliper when that caliper is flushed.
I like the Ate brake fluids.
A Liter is enough to flush the system.
It is all I have used in my dd/track car for over 7 years. Works great, but miss the blue though. Also, it is all I use in my clutch. Never an issue there either.
A quart (1 liter) will be more than enough to flush the lines. Use a turkey baster to suck as much of the fluid from the master cylinder reservoir before you start. Fill the reservoir with new fluid then start bleeding the lines.
e
thanks I think I will give it a try.have an o4 did the brakes and stainless lines.will flush with ate.thanks everyone
Anyone have access to ATE Super Blue, contraband...lol
I have it in my Z now and it's overdue to be flushed...
I have the new ATE fluid but like the swapping of colors...
