CLICK HERE to GROW your shifter in MINUTES for only $20!
I have the RSD shifter which is basically just a cut down C6 Z06 unit threaded 9/16-18 UNF to work with C5 *****.
I wanted to try out a longer/easier throw without swapping shifters AGAIN.
So I found this $20 shock extension that was threaded correctly and tried it out:
Afco Racing Products 20180-1 Shock Extension 2in Std
Here is what it looks like installed, Not bad as the standard-size shift-boot was too large for the RSD shifter. As far as shifting the jury is still out, It might be too long now! They make a 1-inch version that might be a better solution.
