Memory Seat Problem
Old Feb 8, 2016 | 10:51 AM
8VETTE7's Avatar
8VETTE7
Default Memory Seat Problem
Old Feb 9, 2016 | 09:42 AM
8VETTE7's Avatar
8VETTE7
Old Feb 9, 2016 | 09:56 AM
CaseyJones's Avatar
CaseyJones
St. Jude Donor '15-'16
Oh, how many problems I've been having with my car's electrical issues...
Try unplugging the memory module under the driver's seat to test it. That should disable the memory function and the seat should work minus the memory settings. Totally disabling it may also serve to reset it by purging the cached settings. Leave it unplugged at least overnight and then reconnect it to see if that helps.
Marc at Vettenuts.net probably has one.
Old Feb 9, 2016 | 11:45 AM
dadaroo's Avatar
dadaroo
Chuck, I will look into this once I get home. It may very well be the SCM. I have seen something like this before if my old memory serves me.
Mr. Sam
Old Feb 11, 2016 | 06:01 AM
dadaroo's Avatar
dadaroo
Chuck, I think it is the SCM. You could remove the SCM serial bus wire from the Star connector in the passenger side foot wheel.
That should not prevent you from using the FOB to lock and unlock the doors.
Let me know what you think.
Mr. Sam
To Memory Seat Problem
