MAF Cleaning
Can someone please confirm if the following item is what I need to clean the MAF:
Amazon.com: CRC 05110 Mass Air Flow Sensor Cleaner - 11 Wt Oz.: Automotive
Thank you
Thank you
A lot of guys will purchase this one time Combo Pack that also includes a can of Throttle Body Cleaner.
laurent_zo6 (05-05-2016)
Thank you
Thank you
Received 2,182 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Just a NOTE. In the past,, I have used Brake Parts Cleaner to clean mine. Its still working fine..
BC
BC
The following 2 users liked this post by Bill Curlee:
jrprich (04-29-2016),
Amazing how much affect the small things have on our cars. My 04 vert was generally running less than optimal. Slight hesitation, rough idle, not shifting as crisp as usual. It's hard to believe that a dirty MAF could cause all of the above. Took her apart and cleaned the MAF with CRC MAF Cleaner and she's running like new again. The difference in performance is more than noticeable. I'd look there first if you are experiencing the same issues. Probably the easiest fix I've ever had.
