Looking at Tech2 knockoffs but have a few questions re: USB key
#41
Here is a GM 101 list of how to access all the info in the Tech 2. It is PDF so it is searchable.
https://www.corvetteforum.com/forums...101-paths.html
Mr. Sam
Mr. Sam
#42
Here is a photo I took just showing how you can use the Tech 2 together with a windows 10 pc and the TIS2000 running in a virtual XP pc .
I have also connected the USB key to a USB port and it recognized by the virtual pc .
Pounder (04-24-2016)
#43
Dave
#45
Very cool Have you ever flashed any software updates? I've been thinking of one of these clones.......I've seen some warnings that it ruins things.
#46
I bought my C5 and Tech 2 last summer and are trying to learn the Tech 2 and figure out the use of the Tech 2 and the TIS2000 I bought .
As far as I have learned by now is that the main use of TIS2000 is to update an existing PCM or flash a replacement (new) PCM .
As far as I also have learned you download files for your VIN from ac delco site by means of the TIS2000 first . Then you copy these files from the pc into Tech2 memory . Afterwards you connect the Tech2 to the OBD2 plug in car and update according to correct prosedure . I hope you can confirm if this is correct ....
I can´t see any problem with reflashing the PCM using this clone .
This video seems to confirm that the quality is good of these clones .
#47
1/4 mile/AutoX
No I have not done any reflashing with my clone Tech 2 .
https://www.youtube.com/watch?v=ogxTadwPxjw
#49
Yep, a few days ago.
There are two separate software's and versions though for GM and GM NAO from what I see but maybe I'm wrong.
GM NAO 33.002
https://copy.com/ft8g3tPh2f8s
GM 32.008
https://copy.com/GSLr8JdOiBtw
GM NAO 33.002
GM 32.008
#54
GM NAO 33.002
GM 32.008
GM NAO 33.002
GM 32.008
#55
