Front turn signals/flashers issue
I bought a 1999 Corvette 3 weeks ago, anyway I'm new to the car..
Symptom:
Front blinkers and flashers don't blink
However..
DRLs do light up
Rear blinkers and flashers do hyper blink (until I installed hyper flash bypass, now blink normal)
What I've done:
Read a bunch of stuff in the forums..
Replaced the Bulbs
Replaced the Hazard switch
Replaced the Multiswitch
Installed a hyper flash bypass
None of these things have solved the issue, I see this is a common problem but apparently many different causes. If anyone has any other tips or suggestion, I'd much appreciate it. Thanks
Symptom:
However..
DRLs do light up
What I've done:
Replaced the Bulbs
The socket looked to be in good condition, applied a little pressure to the tabs to make sure they were making good contact. Both fuses 15 and 20 are good. And I purchased double filament bulbs from NAPA.
Here is the schematic for where the problem should exist.
https://www.dropbox.com/s/ysvg4c10t9...gnals.pdf?dl=0
Might try swapping one of the DRL relays with a non DRL one just to check. I would be surprised if both are bad but you never know.
If you need any other schematics let me know.
Mr. Sam
Mr. Sam
Jamo2527 (05-01-2016)
Are you sure the DRL lights are on? Check that the heavier filament with shorter legs is the one that lights up in the bulb.
Does the correct filament turn-on with the headlights? It's the finer filament with the longer legs in the bulb.
Do the signals not work with both the headlights on and off?
After all the b.s. I went through this is what did the trick lol, thank you!
While on the topic. I've read a lot about these bulbs burning through the housing. Do LEDs fix that issue? I've heard that they do and I've heard they burn just as hot.
Amazon.com: SiriusLED 2 Piece 48 SMD Amber Orange 3157 Dual Filament LED Light Car Turn Signal Tail: Automotive
Any reason I should go with another set? Thanks
