Stock C5 Z51 spring rates
Can anyone tell me what they are in comparison to coilovers
I found in one thread mention of it being:
C5 Z06: 526# Front, 714# Rear
It mentioned the front is the same on the Z51, so I'm gusesing the rear is greater on the Z06.
However this does not translate right as it's a leafspring vs a coil spring... wheel rate differences right?
That translates to 9.39kg/mm front and 12.75kg/mm which is greater than most coilovers and rear biased.
Not quite sure how to calculate proper comparison.
The reason I'm asking, I want to know how much the car will actually compress per pound, so when I set the height I know how much more or less the car will compress, why? LOL... as one of my driveways is really low... and I don't want to scrape... Softer = car will sit lower with passenger.
No one?
My notes say:
526 front, 634 rear c5 z51
526 front, 714 rear c5 z06
582 front, 793 rear c5 t1
420 front, 657 rear c6
526 front, 645 rear c6 z51
531 front, 782 rear c6 z06
582 front, 850 rear c6 t1
https://www.corvetteforum.com/forums/c5-general/2585013-c5-spring-rates.html#post1574267563.
g/1957758-c5-spring-rates-and-antisway-bar-sizes-97-04-a.html
