What is the purpose of these bolt holes?
Casting was from an older version that required a bracket there. Car is much faster if you put small Allen head bolts in there.
Edit; I have been corrected, please see below... from F-body bracket.
Received 1,261 Likes
it's for a throttle cable bracket for cars that use the same intakes such as fbodies... someone just posted the same question a week or so back
Received 2,180 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Some more interesting facts: The casting on the TOP center of the intake snout is for the addition of an EGR Tube (F-Body) as the C5 does NOT use an EGR System
Received 19,305 Likes
'20-'21-'22-'23-'24
Saw those bolt holes on mine and kind of wondered what they were for. Now I know.
"My Dad's a TV Repairman"
That's where you messed up. Dissimilar metal corrosion caused a side-load vortex inside the throttle body. I used stainless short bolts and got an easy 10 RWHP/10RWTQ. Learned that one from the Chicago Viper guy...
I drilled the threads out and polished the bore...good for about 10HP...
