New 2003 owner, question about some issues with the car
Hi everyone,
I just picked up a black 2003 with 186k miles I know the owner and that it was well taken care of. But there are some issues:
1. service abs, service traction control, service xxxxx comes up when the car is running...it runs fine, but I'm wondering if I'm looking at a computer issue since all this wouldn't go wrong at once. If so, which computer am I looking at?
2. HUD will not move up/down. It works, I can see it if I look from a high enough angle. I see that is a common issue with the plastic gearing. Is it better to try to fix it or just get a replacement?
3. Brakes are horrible at low speeds, almost like warped rotors but wondering if number 1 could be causing ABS to do some shenanigans.
4. Power windows...not smooth at all, sometimes gets stuck going up or down.
5. Is there any way to tighten down these panels in the car. Every one of them seems to rattle
I know lots of issues, and I know what I was getting into to, but I bought it for a project car and got a damn good price based on blue book. Some of this stuff I feel comfortable doing being a car audo /electronics tech back in the day but a lot of it I'd just rather pay to make sure it's done right.
Any info is appreciated.
Andy
Andy
You need to pull your codes...
This file will show you how and what they mean
trudesea (10-20-2016)
Hi everyone,
Andy
Andy
2. i know of no way to repair the hud without replacement. there might be? but i have only heard of pulling one from a donor car and replacing
3. brakes could be crap pads, sticky calipers, air in the lines {highly possible} this also will be a problem with the abs issue and lastly wheelbearings on the way out
4 power windows are another common issue. tracks get sticky and burn up the motors. happens a lot. replace and grease
5. no on the panels. cars left in the sun and driven over a lot of rough roads distort and rattle. there is no fix without a ton of time and dynamat, even that won't cure the fitment problem
if you paid 9-10k for the car it is what it is but you probably have a few thousand dollars in repairs if you really start looking at the car.
kind of hate to say it but imo that's not a well taken care of car. a well taken care of car has no issues, isn't rattling and drives and performs similar to new. it's possible for a c5 to be like this at 168k although i will be the first to admit it's extremely rare to find one
On the Hud read thru this thread... Just a thought
https://www.corvetteforum.com/forums...d-display.html
I guess what I mean by well take care of is drivetrain wise, he didn't track it, changed the oil, fluids etc on a proper maintenance schedule...and the interior looks like new...it was always parked in the garage. But yeah I personally couldn't stand codes being thrown on my car....all these codes are recent and he did not drive the car much the last 6 months, maybe once a week.
I gave 7k for it as I'm having so much fun in a divorce right now and needed a car....why not a vette? lol. Not ready for anything new now...newer vette in a couple years.
Ok, here are the codes coming up. I reset all the codes then went for a drive, making sure I did some mixed driving. Lots of TCS codes
PCM P1689 HC
HVAC B0361 H and B0441 H
TCS
C1241 H C
C1248 H
C1265 H
C1266 H
C1267 H
C1268 H
C1276 H C
PCM P1689 HC
TCS
C1241 H C
C1248 H
C1265 H
C1266 H
C1267 H
C1268 H
C1276 H C
Let us know where you are located. There may be a member that can help diagnose and repair the issues you are experiencing.
If you are in the LA, CA area let me know I would be willing to give a hand with the repairs.
Gary
Gary
Thanks Gary that's very cool and nice of you, but I'm on the other side of the country, Dacula GA about 45 min NE of Atl.
Just going to toss this out there...I have a HUD unit that I repaired the broken pivot pins, replaced with aluminum. It is just sitting on a shelf. If you do not want to take the time to repair yours I will trade you, you just pay for shipping of yours to me and mine to you.
The unit works just fine, I tested it after I made the repair in order to align the mirror.
If interested, contact me via PM.
Later,
Later,
Just going to toss this out there....
I have a HUD unit that I bought to replace the one in my '04 however it was had the broken pivot pins upon arrival. I have since fixed it using an aluminum pin and a rubber grommet, pretty much as shown in the above link. I checked that it worked fine when I had the original HUD out of my car; had to in order to align the mirror.
Anyways if time is short for you or you do not want to take the time to repair yours I will trade you, you just pay for shipping of both units.
If interested just contact me via PM.
Later
Later
My advice is to enjoy the car, not worry about the divorce, and listen to 8VETTE7.......you're in real good hands.
Thanks guys, I'm having to replace all the rotors, they where warped and there was not enough of them to turn. So at least that will take care of that problem.
As far as the TCS codes, does this seem to be a computer issue or am I looking at replacing sensors, etc. Just seems like a lot of failures at one time. I should probably I also clean all my ground points (probably not a bad idea anyway)
C1241 H C
C1248 H
C1265 H
C1266 H
C1267 H
C1268 H
C1276 H C
C1241 H C
C1248 H
C1265 H
C1266 H
C1267 H
C1268 H
C1276 H C
Later
Later
"1. service abs, service traction control, service xxxxx comes up when the car is running...it runs fine, but I'm wondering if I'm looking at a computer issue since all this wouldn't go wrong at once. If so, which computer am I looking at?"
I got this when my TPMS units started going bad. It makes it sound like the world is ending, but it may just be the $50 Tire Pressure units in the tires.
