My idler pulley was sqwealng so I bought all new pulley and belt when I tightened down the idler it doesn't spin anymore the metal dust cover peice doesn't fit flush against the baring and rides in the plastic part of the pulley I called autozone and they confirmed it was the part # they called for. Anyone have an idea of why it's shaped differently?
Got the pulley and tightened the bolt. Pulley rubs and does not clear at the bearing. Solution add a washer to give clearance when bolt is tight. The shield will also fit if you simply add a washer to give the clearance needed.
same problem replacement pulley was about 1/8 in wider then oem this was for a 98 .toke it back .found right fit for a 2001 . go figure . was able to use dust cover that way .
