c5 suspension cradle angle
Old 01-09-2017, 02:35 PM
num1racer
num1racer's Avatar
Default c5 suspension cradle angle
I have a project I am building with C5 suspension and was wondering if anyone knew if the front and rear suspension cradles sat level or if they had an angle with the car sitting on the ground? Any help would be appreciated.
Old 01-13-2017, 01:05 AM
striper
striper's Avatar
I can't answer this positively but from having removed my rear cradle I would bet that the rear is level, I would assume that the front is level too.
Old 01-15-2017, 11:58 AM
C5 Pete
AMP Racing
Support Corvetteforum!
C5 Pete's Avatar
2023 C5 of the Year Finalist - Modified
2017 C5 of Year Finalist
St. Jude Donor '09-'10-'11-'12
The mounting points on the frame are not level, but if you draw a line through the lower a arm mounting points, that is level.
Old 01-15-2017, 03:02 PM
k24556
k24556's Avatar
Default Frame dimensions
See if the attachment will answer your questions.
Old 01-17-2017, 11:20 PM
lionelhutz
lionelhutz's Avatar
Performance Trends Suspension Analyzer has the C5Z model in it. You can download the trial and see the numbers.
And no, the lower a-arms are not level front to rear. The uppers aren't either.
Old 01-18-2017, 02:23 PM
Xav!er
Xav!er's Avatar
I was going to say, level A-Arms certainly dont sound right. Thank you for clearing that up.
To c5 suspension cradle angle
Quick Reply: c5 suspension cradle angle
