C5 ODB2 Port
Old Jan 17, 2017 | 04:25 PM
Luigi Cappel's Avatar
Luigi Cappel
4th Gear
Default C5 ODB2 Port
I'm considering buying a GPS tracking unit that is designed to plug into the ODB2 port. I was wondering if the port was already being used by the Heads up Display, or if it is available for another device.
Has anyone done this before? Is there any reason why you wouldn't?
Cheers
Luigi
Old Jan 17, 2017 | 04:30 PM
aaronc7's Avatar
aaronc7
Should be fine, the open port is below the steering column. Does it just use the OBD2 port for power or other information?
Old Jan 18, 2017 | 01:11 PM
Luigi Cappel
4th Gear
Default Vehicle Tracking
Thanks so much for coming back to me. I think power is the main thing, but at the price point I suspect it also uses the port for speed, revs, harsh acceleration and breaking. I doubt they would use things like accelerometers when they can already get that info from the car.
Ultimately all I want is that if it ever got stolen, I don't want the insurance money, I want my car back I was just wanting to make sure that the HUD wasn't monopolising the ODB2.
Old Jan 18, 2017 | 01:38 PM
sean.b's Avatar
sean.b
not if its the built in/integrated one, no. some aftermarket ones do, but you wouldnt need to ask if that was the case.. it'd be pretty obvious because you'd have to have plugged it in yourself.
Old Jan 18, 2017 | 04:09 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The OBD Port should be open and ready for use. Your HUD plugs into the top of the instrument cluster port.
BC
To C5 ODB2 Port
