2000 corvette output shaft leak
Hello all,
newbe here trying first post. If I'm doing anything wrong here please feel free to let me know!
Anyway have a 2000 c5 with manual trans, with 29,000. miles. Love the thing!
after 3 day trip parked in garage and noticed a silver dollar size oil spot on garage floor from back end drivers side under transmission.
After a bunch of online research it appears that it may be a output drive shaft seal? Apparently it's a common problem and GM even issued a service bulletin about it.
Anybody know anything? Cause, cost to repair, what I should do now, etc.
Any thoughts, experience with it, and or advice would be greatly appreciated.
Thanks a million,
Kevin
Thanks a million,
Kevin
Thanks for getting back to me,
Positive not condensate. Seen that often. No color in it it and heavy viscosity so pretty sure not trans fluid. Heavy weight hypoid oil with slightly dirty brown color is what it seems like. Manual trans but surprised it may contain Dextron 111 auto trans fluid?
Only owned it for a about six months so a little clueless with corvettes.
Thanks.
Pretty sure it is your seal. It's not to bad of a job if your are mechanically inclined. You are basically just pulling the shaft out of the trans unit, replace the seal, and then putting the shaft back in. I think it cost me about $800 eight years ago. This will be a good time to verify the rubber boots are still good.
Beary
Beary
2000 black c5 (03-27-2017)
Received 2,180 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
YES !!!! Trans takes DEXTRON.
Here is something that you should enjoy:
- C5 Differential Seal replacement: http://forums.corvetteforum.com/c5-g...on-photos.html
- C5, ragtopws6 , Upgrading your C5 rear with C6 Z06 guts, : http://forums.corvetteforum.com/c5-g...-z06-guts.html
- C5, Its_Go_Time, Output Shaft Install - Left and Right: http://forums.corvetteforum.com/c5-t...post1573407966
- - C5 BEST DRIVE TRAIN POST GOING: https://www.corvetteforum.com/forums...post1591614975 https://www.corvetteforum.com/forums...post1591614975
seal
Thanks a million really appreciate the help!
Beary
Beary
seal
Thank you! Appreciate the help. Don't know about enjoying (Bigger job than i had hoped) but such is life.
Thanks again!
Thanks again!
ps
Anybody know of any repair shops in San Francisco/ Bay Area that you could recommend that can do output shaft seal diagnosis/repair? Looks to be beyond my ability.
I should probably be posting this request somewhere else on this site. I'm brand new at this and pretty clueless. Will learn and try not to waste anyones time.
Thanks Again!!
Thanks Again!!
