Found Tach signal wire under drivers side of dash <BIG PICS>
Old 02-17-2012, 12:10 AM
  #41
VGLNTE1
VGLNTE1's Avatar
St. Jude Donor '14-'15
I have the right tach wire. The instructions neglected in telling me LS motors should use the 4 cylinder mode
Old 02-17-2012, 12:11 AM
  #42
RX-Ben
RX-Ben's Avatar
Well, you got the hard part out of the way. All the white wires were a no-go for me.
Old 02-17-2012, 12:40 AM
  #43
VGLNTE1
VGLNTE1's Avatar
Just cut one in half till your tach dosnt work. Lol.
Old 06-06-2013, 10:05 PM
  #44
Arnie Chamberlain
Arnie Chamberlain's Avatar
Update: I just did this and it worked perfectly.
Power and ground were tapped into accessory plug on passenger side by the PCM. Tach was taken from the white wire near the gauge cluster, but on my car, I had two "bone" white and one "pure" white. I guessed the oddball was the tach signal, and I was right. The "Pure"white wire was also marginally thicker.
Car for reference is a 2002 6 speed coupe (not Z06)
Old 06-25-2013, 06:17 PM
  #45
c5vette211
c5vette211's Avatar
St. Jude Donor '14
I am doing this install right now and the 04 does not have the same coloring....
Old 10-07-2014, 07:37 PM
  #46
Stroker87
Stroker87's Avatar
I just installed a Raptor Shift Light in my 03 zo6
in my car I had a total of 4 white wires one was a little thicker (was not it) it was one out of the Three small wires witch I thought I had a bad light until I found the 4th white wire (yup the last one I found)
hope this help some one else!
Old 11-09-2015, 12:33 AM
  #47
Ls2gtoowner
Ls2gtoowner's Avatar
Bringing an old thread back to life. Anyone know where I can find the pics?
If anyone has them send them to my email
Ls2gtoowner@yahoo.com
Old 11-09-2015, 10:18 PM
  #48
Ls2gtoowner
no one??
I have spent the last 3 hours looking for the wires and I have no point of reference so I am going in blind. I can't get to the PCM because of where the car is and I can't move the car because I just had surgery on my left leg. any help would be greatly appreciated.
Old 11-11-2015, 09:13 AM
  #49
Stroker87
Stroker87's Avatar
Originally Posted by Ls2gtoowner
no one??
its been a little while since i installed mine but IIRC under the drivers side dash theres a bundle of wires on the left side of the steering column one of the white wires in that bunch is the one you need
Old 11-21-2015, 11:45 PM
  #50
Ls2gtoowner
I found it thank you. All of them were the same white. It is the wire more buried in the harness. At least mine was.
Old 11-22-2015, 01:09 PM
  #51
Stroker87
Stroker87's Avatar
no problem! glad i was able to help
Old 12-10-2015, 08:53 PM
  #52
Flyin'Brian
Flyin'Brian's Avatar
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Pictures are Fixed
Old 05-22-2016, 12:34 PM
  #53
yoshgixxer
yoshgixxer's Avatar
Just wanted to bump this, my tac wire was also a more darker shade of white like a bone white not bright white like the OP said. Also touching the wire with my ground probe did make the tac needle jump to verify it was the correct wire... Also told me to check my charging system to for some reason when I grounded the tac wire lol went away with a key cycle. Anyways thanks for making my shift light install a super quick process!
Old 05-22-2016, 12:36 PM
  #54
yoshgixxer
yoshgixxer's Avatar
Installed pic... Also the smaller pink wire off of the ignition worked perfect as my switched 12V!
Old 05-22-2016, 08:59 PM
  #55
Stroker87
Stroker87's Avatar
i dont like that location the light should be more in your face, on a bright day you wont even see it flash
Old 05-22-2016, 10:17 PM
  #56
yoshgixxer
yoshgixxer's Avatar
I tried it today, I can see it during the day though it's not crazy in your face , at night it's plenty bright,. Good thing 99% of the "activities" go down at night around here lol
Old 05-22-2016, 10:31 PM
  #57
Stroker87
Stroker87's Avatar
yeah we have mexico nights around here but some times get the daytime run lol
To Found Tach signal wire under drivers side of dash <BIG PICS>
Old 05-22-2016, 11:45 PM
  #58
yoshgixxer
yoshgixxer's Avatar
Lol run em till the wheels fall off or the sun comes up... God bless the Mexico racing league hah!
Old 07-10-2016, 07:55 PM
  #59
transamman08
4th Gear
transamman08's Avatar
Default I have a 02 corvette and i can't seem to find this wire.
Originally Posted by Flyin'Brian
I didn't want to pull the wheel and run a wire from outside for my shift light, so I did some research in the service manual and found a better closer place to connect.
Here are some pictures. Hope these help someone!!
Remove bottom of dash
IC plug that this harness feeds. You can see in the pic of the plug what all the other wires do
This is the harness that the wire is in
A look at all the wires in the harness
Here the wire is isolated from the rest
A close up of the White tach signal wire. there are 3 small 18g white wires, but I noticed that the one that we need is a little bit off white (like bone white?... they may not all be like that
[Modified by Flyin'Brian, 12:25 PM 8/2/2003]
I can't seem to find this wire. Ive put 3 t tap connectors over all 3 18gauge white wires plus the 16 guage white wire and only one does like a flicker with the numbers on my tach, but it mostly stays at 0 and doesn't do anything. I dont know what else to do.
Old 07-10-2016, 07:58 PM
  #60
transamman08
4th Gear
Default reply
did you use t tap connections or did you just splice the wire? i have put 3 t tap connectors on all 3 18guage white wires and one flickers my numbers but stays on 0 unless i jiggle the wire and then it shows random numbers. I have a shift light that has a digital tach readout in the middle of it.
Quick Reply: Found Tach signal wire under drivers side of dash <BIG PICS>
