Found Tach signal wire under drivers side of dash <BIG PICS>
Old 07-16-2016, 10:07 AM
  #61
yoshgixxer
yoshgixxer's Avatar
I used the T tap type connector, if it's moving the tac needle at all I'd figure that's probably the right wire? Did you try it for ***** and giggles to see if your light works?
SMaster (07-16-2016)
Old 01-12-2017, 06:51 PM
  #62
hatewhatownsyou
hatewhatownsyou's Avatar
Pro tip: using a test light will NOT STROBE the probe bulb. But it will drop the RPM needle to 0 when you find the correct wire.
Unless I'm the only idiot who didn't know this.
Old 01-04-2018, 06:34 PM
  #63
STL Mike
STL Mike's Avatar
Looking for the pics and can't seem to find them. Anyone have them?
Old 01-19-2022, 07:14 AM
  #64
joenationwide
joenationwide's Avatar
Default More pics
Back of the gauge cluster showing the connector port.
Here is the connector
A17 pin (last one) is the tach signal
Here’s the harness loose
I marked the wire, cut it, and spliced in another wire that I can use to activate a switch (or shift light) at a desired rpm.
Quick Reply: Found Tach signal wire under drivers side of dash <BIG PICS>
