How much does temperature affect H.P?
Old 09-29-2003, 08:38 PM
lager99
lager99's Avatar
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Default How much does temperature affect H.P?
It's starting to cool off up here and my car feels like it's just ripping lately! :steering: Feels like an extra 20 horse. :reddevil I love it! Traction's a problem on the cold asphalt though.
:p:
Old 09-29-2003, 08:44 PM
jschindler
jschindler's Avatar
Default Re: How much does temperature affect H.P? (lager99)
You are probably correct. On a car like our C5's the ambient temperature can pretty easily swing the rwhp by 30. I have personally seen a 2 MPH difference in the quarter mile and hour trap speed just from 90 degrees to 60 degrees.
Old 09-29-2003, 08:53 PM
lager99
lager99's Avatar
St. Jude Donor '06
Default Re: How much does temperature affect H.P? (jschindler)
Wow!! :eek: That's huge! I'd like to dyno it at these temps. :thumbs:
Old 09-29-2003, 09:00 PM
CJS
CJS's Avatar
There is a member on this forum who is in Alaska and drove his Vette in something like -20 degree temperatures! He said it was like his stock C5 was like a Z06! I have driven my modded Vette in 20 degree clear cold temperatures, and it was like a different car!
Old 09-29-2003, 09:11 PM
clem zahrobsky
clem zahrobsky's Avatar
Cruise-In I Veteran
Cruise-In II Veteran
you get a 1% increase in HP for every 10 degrees you lower the intake air temp. :chevy
Old 09-29-2003, 10:09 PM
Evil-Twin
Evil-Twin's Avatar
Received 3,812 Likes on 1,925 Posts
St. Jude Donor '03-'04
10 degrees cooler (intake temp) will gain you about 1% horse power
[Modified by Evil-Twin, 8:46 AM 9/30/2003]
Old 09-29-2003, 10:17 PM
LittleBoyBlu99
LittleBoyBlu99's Avatar
Default Re: How much does temperature affect H.P? (clem zahrobsky)
:skep: :skep: :cool: :cool: :confused:
Old 09-29-2003, 10:21 PM
BLU-BY-U
BLU-BY-U's Avatar
Default Re: How much does temperature affect H.P? (Evil-Twin)
10 degrees cooler (intake temp) will gain you about 1 horse power
you sure about that?
Old 09-29-2003, 10:42 PM
lager99
lager99's Avatar
St. Jude Donor '06
Default Re: How much does temperature affect H.P? (BLU-BY-U)
Those #'s conflict each other. :skep:
Old 09-29-2003, 10:48 PM
1hkdup996spd
1hkdup996spd's Avatar
I've heard that every ten degree drop is a 3% dain in horsepower. If you do the math this turns out to just over a 1 horsepower gain for every 1 degree drop in temperature on a stock ls1.
Old 09-29-2003, 11:17 PM
Midwayman
Midwayman's Avatar
Assuming the pressure stays the same...
Correction factor (Cf)
Temperute in Celsius(Tc)
Cf=1.18((Tc+273/298)^0.5)-0.18
So at 25 degrees C, the CF is 1 (STP or around room temp)
http://wahiduddin.net/calc/cf.htm
So its ~1.11% hp per 10degrees F temp change (no humidity or pressure changes)
[Modified by Midwayman, 4:24 AM 9/30/2003]
Old 09-30-2003, 10:42 AM
lager99
lager99's Avatar
St. Jude Donor '06
Default Re: How much does temperature affect H.P? (Midwayman)
I would go with that. :yesnod: Im my RWHP is 387 and morning temp is 30 degrees F than it would be a 5.55% increase, 408 RWHP. 21 ponies. :thumbs: Pretty close guess. :cheers:
Old 09-30-2003, 11:01 AM
Mean Green
Mean Green's Avatar
CI III & IV Vote Ho
CI II, III, IV & V Vet
CI IV Bracket Champ
My old vert would turn 13 flat in the middle of the FL summer and on a nice cold day this past Jan at Gainesville Raceway she turnd a 12.47 :eek: :D
So my answer is about 1/2 second depending on the temp swing :)
Old 09-30-2003, 04:50 PM
beckel
beckel's Avatar
If this is true, than does anyone know at what temp. the factory quotes their hp figure ?
Old 09-30-2003, 04:58 PM
clem zahrobsky
Cruise-In I Veteran
Default Re: How much does temperature affect H.P? (beckel)
SAE standard is 77 degrees. race shops use 60 degrees
Old 09-30-2003, 05:55 PM
Midwayman
Midwayman's Avatar
One would assume the factory is using SAE corrected numbers, but you never know....
Old 09-30-2003, 06:56 PM
NEPTUNEBILL
NEPTUNEBILL's Avatar
A couple of years ago when tuners were working on the 160 degree stats etc one of them found that a stock ls1 produced max power at 178 degrees on the dyno, he also stated that at 200 degrees it cost about 15 rwhp. FWIW
To How much does temperature affect H.P?
Quick Reply: How much does temperature affect H.P?
