door molding removal
If you are talking about the body side moldings, there are no holes behind the BSMs. Questions regarding removal of the BSMs are asked quite often here on the Forum. Here are some of the more recent threads on this subject:
BSM removal
How to REMOVE body side moldings?
BSM Removal Nightmare
For Those Who Removed the BSM From Your Doors, What Was The Outcome.
Bsm...
Using the Forum Search feature, you may find even more threads on this topic.
Good luck!
BSM removal
Bsm...
Good luck!
Are you talking about the panels on the inner side of the doors? If so, yes, there are holes. Plastic clips go in them, and you'd do very well to use the special panel removal tool from Autozone, Pep Boys or any decent car shop. I'd also pick up a few extra clips....I usually break a few.
Supporting Tuner
