[Z06] 2003 ZO6 Tire Size
Old 03-30-2005, 10:05 AM
davidp
davidp's Avatar
Default 2003 ZO6 Tire Size
I know this is probably like beating a dead horse, but here goes.
What tire size can I upgrade to (the largest) front and rear on stock ZO6 wheels, without having any clearance problems?
Thanks in advance
Old 03-30-2005, 10:39 AM
john anderson
1st Gear
john anderson's Avatar
Default tire size
I've the exact same question, but don't have the answer. I don't see the need to duplicate your inquiry. When and if you get the answer would you pleas e-mail me at jaflamethrower@aol.com.
Thanks, Flame Thrower!
Old 03-30-2005, 10:50 AM
OutlawDon
OutlawDon's Avatar
305/35/18 to 315/30/18
Old 03-30-2005, 11:34 AM
l2vette
l2vette's Avatar
Those are not the stock wheel sizes.
Old 03-30-2005, 03:21 PM
dtwalkerfl
dtwalkerfl's Avatar
315/30-18's will give you a shorter tire than the stock ones in rear (25.44 diameter compared to stock 26.13 diameter)
305/35-18's will give you 26.41 diameter and will effect your speedo slightly.
He didn't go into front sizes.
I am upgrading to 275/35YR18 fronts and 295/35YR19 rear (BFG G-force T/A KDW-2 tires) on new C6 wheels. The problem is in the rear wheel offset. The C6 rears have a +79mm offset and the stock Z06 rears are +58mm. I had to order spacers specially machined to move the wheels out on the rear. The fronts are the same stock offset (+56mm).
Old 03-30-2005, 09:04 PM
OutlawDon
OutlawDon's Avatar
Stock wheel sizes?? He wasn't asking about the wheel sizes.
He asked for the biggest tires possible and I gave him suggestions.
Old 03-30-2005, 10:02 PM
Dr.Ron
Dr.Ron's Avatar
Location: 2007 Nat'l Corvette Challenge 11.50 index Champ. New Jersey
I think the Outlaw gave a size upgrade range....
Ron
Old 03-30-2005, 11:39 PM
davidp
davidp's Avatar
Hey dtwalkerfl, Thanks, would the results of the 305's on the speedo be minimal?
Thanks Again
Old 03-31-2005, 01:09 AM
OutlawDon
OutlawDon's Avatar
305's will be fine. Won't screw with the ABS/TC sensors. Speedo will just be slower than actual speed, but very very minimal. Less than 2% difference.
Old 03-31-2005, 10:05 AM
tlaselva
tlaselva's Avatar
Below is a post for upgraded rims and tires from a experienced racer on this forum.
Sorry, forget his screen name....
Whomever you are, I hope you don't mind...
I recommend:
305/30x18 on 10.5x18 with +0.25" offset for the front
and 315/35x17 on 11x17 with +0.25" offset in the rear.
This neutralizes the handling, increases front grip, increases front turn in, decreases braking distance, increases front steering response and modulation, reduces understeer and stabilizes the flex of the front side wall.
It also increases rear traction under hard acceleration and cornering allowing the car to "squat" better.
This results in higher corner entry speeds, mid corner speed and corner exit speed.
Old 03-31-2005, 04:43 PM
Monnie
Monnie's Avatar
Originally Posted by tlaselva
Below is a post for upgraded rims and tires from a experienced racer on this forum......
I recommend: 305/30x18 on 10.5x18 with +0.25" offset for the front
This neutralizes the handling.........
Would this be BETTER than stock? Or is this just the best option ONLY if you wantt o upgrade??
To 2003 ZO6 Tire Size
Quick Reply: [Z06] 2003 ZO6 Tire Size
