[Z06] VIDEO at Idle plus streetability and WOT with my 511rwhp / FTI
#181
OEM pump and OEM pressure Regulator checked at 58.5 PSI...
The same Injectors were running ~ 45% on my 346 CiD...and now 97% on a "cold" day with my last stroker.
OEM pump still in the tank.
Christian
#183
Supporting Tuner
#184
I have updated my Photobucket and updated most of the Pictures and Video (MP4) links because this thread is still watched, hope it helps.
Christian
Christian
#186
I am looking at doing a similar build to reach around 500rwhp, however I want to use a set of 243 heads (ported and milled). My question is what are your thoughts about PTV issues with the came cam that you ran? I have attempted to contact FTI with no response.
#187
Did you email FTI?
