[Z06] GM Parts House July 2007 C5 Specials!
Premium Supporting Vendor
Hi All,
Welcome to the ever so popular C5 specials. We had a price increase on some things from GM this month, but overall it wasn't bad at all.
As always, if you'd like to order online you can go to the site at www.gmpartshouse.com. Click where it says click here to enter part number search. Use the part number given under Chevrolet make.
Thanks, Gene
||--Genuine GM Key FOBS/Transmitters--||
10253839 – 97-99 – 90.77
10432147 – 00 – 90.77
||--Genuine GM Radio Surround Bezel--||
10407815 – Ebony – 117.73
||--Genuine GM Tune-Up Items--||
12495519 – GMPP red spark plug wire set – 52.92
12571164 – GM AC Delco Iridium spark plugs – 5.88 each
10287788 – 97 & 98 fuel filter – 10.80
10299146 – 99 – 04 fuel filter/pressure regulator – 42.73
||--Genuine GM Sport Seat Foams/Pads--||
97/98/99/00
10273418 – D/S & P/S seat back outer foam – 24.71 each
10283891 – D/S & P/S seat back insert foam – 48.63 each
10273420 – D/S & P/S seat cushion foam – 63.92 each
Complete set of 6 seat foams/pads 301.15 shipped
01/02/03/04
10273420 – D/S seat cushion foam – 63.92
88991516 – P/S seat cushion foam – 43.51
Complete set of 6 foams/pads 278.76 shipped
||--Genuine GM Radiator Cage/Skid Plate--||
10400765 – Radiator cage – 209.29
To bolt everything to the cage you need to purchase a pack of 10 nut inserts for the bolts to be able to screw into and you need 10 bolts.
11515757 – Bolt – 1.18 each (10)
10281493 – Nut insert – 1.03 each (10)
||--Genuine GM 3 Piece Frt Spoiler/Air Dam--||
10401458 – Center – 53.76
10419312 – LH – 8.76
10419313 – RH – 11.65
||--Genuine GM C6 Z06 Shocks--||
10313647 – Z06 Front Shocks
10318361 – Z06 Rear Shocks
Both sets of front and rear shocks (4) 228.86 shipped.
For the shocks on our website, use part number c6z06shocks under Chevrolet make.
The C6 Z06 shocks will work on C5’s without modification. Not recommended for C5’s that are completely lowered on stock bolts.
||--Genuine GM C6 Z06 Engine Components--||
24238412 – LS7 Clutch
12571611 – LS7 Flywheel
Both LS7 Clutch and LS7 flywheel are 464.24 shipped.
For both clutch and flywheel on our website, use part number ls7clutchkit under Chevrolet make.
89059282 - LS6 Slave Cylinder – 113.61
12564455 - LS6 Master Cylinder – 115.87
14061685 – Pilot Bearing – 10.59
*Clutch does work in any LS1/LS6 drivetrain but must also have ls7 flywheel.
Also, can only use LS1/LS6 hydraulics.
||--Genuine GM C6 2007 Z06 Shifter Kit--||
25823571 – C6 Z06 shifter
10354701 – C6 shift ****
11609670 - Bolt
Complete kit 181.63
For this kit on our website, use part number 07z06shifter under Chevrolet make.
||--Genuine GM Engines--||
12498399 – 2002 + LS6 engine – 4795.00
12480030 – GM Performance Parts C5R block – 6450.00
12568950 – LS2 bare block – 1049.99
12572808 – 6.0 cast iron bare block – 759.95
||--Genuine GM Z06 Suspension Components--||
Z06 caliper set – 420.79 shipped
On our website, use part number c5z06calipers under Chevrolet make.
Z06 front screens – 150.85 shipped
On our website, use part numbers 10424820 and 10424821 under Chevrolet make.
Z06 front brake ducts – 49.25 shipped
On our website, use part numbers 10295976 and 10295977 under Chevrolet make.
Z06 rear screens (scoops) – 153.21 shipped
On our website, use part numbers 10322761 and 10322762 under Chevrolet make.
Z06 rear brake ducts – 48.53 shipped
On our website, use part numbers 10425976 and 10425977 under Chevrolet make.
Z06 2004 shocks – 432.68 shipped
For all 4 shocks, use part number 04z06shocks under Chevrolet make.
Z06 sway bar kit (insulators, bars and metal end links)– 299.48 shipped
On our website, use part number c5z06bars under Chevrolet make.
Z06 sway bar kit (insulators and bars only, no end links) – 209.53 shipped
On our website, use part number c5z06barsNL under Chevrolet make. NL stands for no end links.
Z06 front brake pads – 88952008 – 125.04
Z06 rear brake pads – 12530688 – 58.20
Z06 rear differential assembly – 12572683 – 1214.92 shipped
Z06 front suspension spring – 15233396 – 457.08
Z06 rear suspension spring – 22188038 – 457.08
||--Genuine GM HUD Setup--||
10279814 – HUD
12198648 – Switch
10425223 – Bezel
Total setup is 328.77 shipped!
||--Genuine GM Tire Pressure Sensors/TPM--||
2001-2004 Sensors
25773946 - sensor – 34.20 each
15234846 - nuts – 3.16 each
Total setup of 4 is 163.94 shipped!
97-2000 Sensors
10438853 - sensor – 83.04 each
Total setup of 4 is 378.25 shipped!
||--Genuine GM LS2 Items--||
89017648 – LS2 intake manifold – 276.37
12570790 – LS2 throttle body – 274.40
12572174 – LS2 fuel rails – 129.04
89017587 – LS2 injector o-rings – 24.41
||--Genuine GM LS6 Intake Manifold--||
88894339 - Intake Manifold Only - 472.62!!
Intake with coolant pipe and plugs – 510.22 + 15.50 shipping.
For website ordering use part numbers:
88894339 – Intake
12602544 – Coolant Pipe
12602540 – Coolant Plug Qty 2
Online orders will show higher than 15.50 shipping.
We will adjust the shipping charge after your order is placed.
||--Genuine GM UltraGuard UPF 44 Oil Filters--||
25329389 - UPF 44 Oil Filter
Must order in cases of 6 @ 53.25 shipped!!
||--Genuine GM Cylinder Head Bolts And Gasket Kits--||
12498543 - 97-01 LS1 Engine Head Gaskets (2) – 39.48
12498544 - 02-04 LS1 & LS6 Engine Head Gaskets (2) – 28.56
12498545 - 97-12/03 LS1 & LS6 Engine Head Bolts – 20.16 per head
17800568 – 01/04 – present LS1/LS6/LS2 Head Bolts – 18.48 per head
If you’re not sure which bolt kit to use please email us your VIN# and we’ll tell you!
||--Genuine GM C5 Ceramic Brake Pads--||
88909667 – Front ceramic pad kit
88909668 – Rear ceramic pad kit
Both front and rear ceramic pad kits 131.11 shipped!
||--Genuine GM Brake Rotors--||
OEM
10445856 – RF rotor
10445857 – LF rotor
10445858 – RR rotor
10445859 – LR rotor
Front and rear rotor sets 272.34 shipped!
AC Delco Performance Drilled/Slotted
88926731 – RF rotor
88926732 – LF rotor
88926733 – RR rotor
88926734 – LR rotor
Front and rear rotor sets 258.78 shipped!
||--Genuine GM T1 Engine/Suspension Items--||
T1 shocks – 675.36 + 28.50 shipping
T1 trans cooler – 974.82 + 28.50 shipping
T1 sway bar pkg with insulators and end links – 754.29 + 35.00 shipping
T1 complete suspension package – 2968.04 + 75.00 shipping
T1 suspension springs 795.99 each + 28.50 shipping each
For all T1 related items please call us to order and for availability.
||--Genuine GM Engine Parts--||
12564824 - '02 LS6 Cylinder Head (Assembly) – 791.56 each
12564825 - '02 LS6 Cylinder Head (Bare) – 583.89 each
12480110 - ASA Racing Cam - 402.50
12480033 - LS1 Hotcam Kit - 459.66
88958622 - LS6 CNC Ported Cylinder Head (Assembly) - 1022.39!! each
||--Helms Service Manuals--||
'97'- '07 Corvette - 125.18 shipped!!
Please Call For Any Other Make/Model Vehicle!
For ordering service manuals on our website, use part number helmsmanuals under the Chevrolet make. Please include year, make and model in the comments section.
||--Genuine GM LS1/LS6 Fuel Rail Covers--||
12559261 - '97-'98 LH Fuel Rail Cover (Black With Red "Corvette" Lettering)
12556455 - '97-'98 RH Fuel Rail Cover (Black With Red "Corvette" Lettering)
Both FRC’s 59.36
12561503 - '99-'02 LH Fuel Rail Cover (Black with Red "Corvette" Lettering)
12561502 - '99-'02 RH Fuel Rail Cover (Black with Red "Corvette" Lettering)
Both FRC’s 70.52
12564257 - '01-'02 LH Fuel Rail Cover (Red With Black "Corvette" Lettering)
12564258 - '01-'02 RH Fuel Rail Cover (Red With Black "Corvette" Lettering)
Both FRC’s 104.20
Thanks, Gene
97/98/99/00
01/02/03/04
11609670 - Bolt
Complete kit 181.63
10279814 – HUD
12198648 – Switch
10425223 – Bezel
2001-2004 Sensors
97-2000 Sensors
88894339 – Intake
OEM
10445856 – RF rotor
10445857 – LF rotor
10445858 – RR rotor
10445859 – LR rotor
88926731 – RF rotor
88926732 – LF rotor
88926733 – RR rotor
88926734 – LR rotor
Both FRC’s 59.36
Both FRC’s 70.52
Both FRC’s 104.20
__________________
Phone: 484-334-8833
Owner of CULTRAG Performance
Shop Our Factory GM Parts Website
Phone: 484-334-8833
St. Jude Donor '08
Gene-
Do you have the plastic trim piece that goes around the ignition? Not the whole radio bezel just the very small piece. Thanks!
Thanks, Gene.
